tennis4you Posted June 2, 2012 Share Posted June 2, 2012 Is there a setting that you can change in AutoCAD that will allow you to change all colors in a x-ref file, even if the "By Layer" color has been changed in the x-ref? Thanks! Quote Link to comment Share on other sites More sharing options...
nestly Posted June 2, 2012 Share Posted June 2, 2012 I don't believe you can change the display of something with a property override except perhaps by using a plot style (STB?), which you can then apply to a Layout in the Page Setup Manager. Quote Link to comment Share on other sites More sharing options...
Blackfish Posted June 2, 2012 Share Posted June 2, 2012 Do you want to change all colors in a source file (the original file you xrefed to your drawing) or just change colors of all layers of the xref in your drawing? These two ways are completely different things... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 4, 2012 Share Posted June 4, 2012 Is there a setting that you can change in AutoCAD that will allow you to change all colors in a x-ref file, even if the "By Layer" color has been changed in the x-ref? Thanks! Everything in the XREF file has to be set to By Layer. You can do this with the SETBYLAYER command. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 4, 2012 Share Posted June 4, 2012 I just verified that plot styles can definitely over-ride property over-rides (native and xref'd objects) Quote Link to comment Share on other sites More sharing options...
troggarf Posted June 4, 2012 Share Posted June 4, 2012 VVA has done quite a few variants found at the link below. The.lsp that I am pointing you has 4 different options on how to handle changing colors in drawings with XREFs so please read the options. If this routine doesn't help then browse the rest of that thread because VVA and LEE made about a ton of variants at peoples request... http://www.cadtutor.net/forum/showthread.php?533-Lisp-colour-change-for-all-layers-and-blocks&p=221559#post221559 Quote Link to comment Share on other sites More sharing options...
