Results 1 to 7 of 7
Thread: Beginner
    Forum Newbie
    not applicable
    Jun 2012
    2
    Unhappy Beginner
    hi,im new to SW. currently im working on school project, where i need to build race car (F1 in schools). my question are:
    1. what way should i start my design process? should i draw plane by plane and mate them? or directly cut design from balsa wood.sltr that ive made in beginning?
    2. instead using fillet/drawing tools what is the other way to draw/blind cut a nice semicircle nose cone?
    3. when i extruded my 2nd cut, it will ruin my 1st cut. any tips on this?
    TQ.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Attach your sldprt file here.
    Tutorial 6 is a toy car tutorial - but a bit different than what you are after.
    http://home.pct.edu/~jmather/content..._tutorials.htm
    You can probably get what you want with 2 extrusions - one from a profile of the top view and another (intesection - cut all outside) from side view.
    Then maybe some fillets.
    Think of how you will actually cut the form (I'm assuming using a band saw and then some sanded radii).
    Attach your file here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    not applicable
    Jun 2012
    2
    my design is horrible,
    have a look and tq.
    Balsa wood.SLDPRT
    D1.SLDPRT
    P1.SLDPRT
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Unfortunately you are using a later version - so I cannot open your files, but stick around a bit and I'm sure Matt will take a look and offer some suggestions.
  5. #5
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    Quote Originally Posted by hurrricaneFone View Post
    TQ.
    Hurricane, were you asked to produce a SW model without having any guidance? I can't open a future version here at work but i have 2012 at home. Check out the lessons on my website in the mean time and i will try to make some time to open your files either tonight or tomorrow and have a look.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  6. #6
    not applicable
    Sep 2008
    VA
    2,859
    hurricane, give this link a try.
    http://www.solidworks.com/sw/docs/F1...olsRaceCar.zip
    it should be a step by step F1 c02 car. I think its what you are trying to do and may help you along the way.
    www.mysolidbox.com
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
  1. Help for a beginner
    By zely in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2011, 03:39 pm
  2. 3D beginner
    By Gra_Dun in forum Map 3D
    Last Post: 1st Dec 2010, 01:38 pm
  3. Beginner 3D Help
    By Ritch7 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Nov 2008, 04:17 pm
  4. beginner in 3d
    By chrisdarmanin in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jan 2008, 03:01 pm
  5. beginner
    By manyos in forum AutoCAD Beginners' Area
    Last Post: 18th Feb 2006, 08:16 pm
