BALLER15LO Posted June 3, 2012 Share Posted June 3, 2012 Hello all, I was wondering if there is anyway to change options in the plot menu. For example I have a long list of printer's and many duplicates, when I only use 2 of the 25 printers on the list. I would like to just have the 2 printers i use displayed, rather then having to search through all the names every time. There is other options I wish to customize in the plot-model tab as well. Thanks for any help in advance! Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 3, 2012 Share Posted June 3, 2012 Have you tried deleting the duplicate printers via the Windows Control Panel yet? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 3, 2012 Share Posted June 3, 2012 Hello all, I would like to just have the 2 printers i use displayed..... You don't even have to see the display (for all future work) (once you set up your template). If you set up your template with layouts to use these two printers, then all you have to do is select the layout to print. AutoCAD will take care of the rest. Set it and forget it. Quote Link to comment Share on other sites More sharing options...
