Results 1 to 10 of 10
    Full Member baker's Avatar
    Civil 3D 2012
    May 2011
    74
    Question Upgrade to Civil 3D 2013 and AutoLoad error...
    Okay, over the weekend we upgraded to Civil 3D 2013. I verified my support paths and all my settings. everything is a go. I open acad2013doc.lsp and add; (load "U:/ACAD-CPIS/LISP/startup-2013.lsp" "")
    startup-2013 contains autoloads for some quirky lisps i have created or saved over the years. for instance (AUTOLOAD "PRG" '("PRG")) the prg lisp is just a lisp that purges registererd apps, and then purges the drawing about 3 times and one or two other setting changes. the PRG.lsp works fine in 2013, but when the "startup" lisp tries to autoload, i get the following error; error:no function definition: AUTOLOAD
    I even get teh same error when i use Vlisp to load the startup lisp. However, when i "comment" all my autoloads, the startup lisp loads fine.
    why do my "autoloads" not load?
    Jon Baker | Civil 3D Senior CAD Designer
    Campos EPC, LLC
    1401 Blake Street | Denver, Colorado 80202
    855-CAMPOS1 (226-7671) | Fax 303-904-0570
    (Civil 3D 2015 SP1 on Windows 7 Professional 64bit)
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Your first mistake was to modify Acad####Doc.lsp (in your case Acad2013Doc.lsp), which is an AutoCAD Owned file that can be overwritten during an Update without notification.
    Autoload is a LISP function that is included within Acad####Doc.lsp, which suggests that your Autoload statements are being called prior to Autoload even being defined... prompting the error you're currently receiving.
    Any/all custom, corporate, or internal LISP loading should be included within the User Owned files Acad.lsp, AcadDoc.lsp, or [YourEnterpriseCuixFileName].mnl only. Each has it's own purpose, and will persist during an Update.
    If the needed file(s) do not exists, simply create them, and store them in the top file path in your Support File Search Paths (SFSP).
    HTH
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Civil 3D 2012
    May 2011
    74
    okay.. will change.. however.. this worked fine in 2012. when i added to the acad2012doc.lsp...
    Campos EPC, LLC
    Civil 3D 2012
    May 2011
    74
    alos.. from the commad line in 2013
    So I tried load vs. autoload in2013;
    Command: (load "Y:/ZCenterPoint/CAD/LISP/c-layers.lsp")
    C:CL
    Command: (autoload "Y:/ZCenterPoint/CAD/LISP/c-layers.lsp")
    ; error: no function definition:AUTOLOAD
    Command: (autoload "Y:/ZCenterPoint/CAD/LISP/c-layers.lsp" "cl")
    Campos EPC, LLC
  5. #5
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by baker View Post
    Especially as you progress with your LISP development, I suspect you'll come to appreciate the distinction here.
    More accurately, improperly using Acad2012Doc.lsp was successful _only_ as a result of the Autoload function having been already defined.
    If the Autoload function is still not defined after a normal startup, with an unmodified Acad2013Doc.lsp, then check that Autodesk has not removed the function's definition from the file.
    I have not noticed this with AutoCAD 2013 at home, but can verify tonight after work.
  6. #6
    Civil 3D 2012
    May 2011
    74
    so.. i created an acaddoc.lsp in my root support directory. Should i justuse the (load ".....") function for the lisps rather than AutoLoad? isearched this in the autodesk discussions as well, and seems to be an issue..
    Campos EPC, LLC
  7. #7
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Most unfortunate... I'll definitely have to confirm this for myself from home.
    If Autoload is not defined then you are relegated to using Load statements instead; a simple Ctrl+H can be used from VLIDE to replace all in one action. This is the best suggestion I can make at this time.
    Cheers, Baker
  8. #8
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    FWIW -
    The Autoload function _is_ included within Acad2013Doc.lsp, line 249, and more completely the _autoqload function (which Autoload is dependent upon) is included at line 226 of the same file.
    If you start Civil 3D, and Autoload is not yet defined, then try manually loading Acad2013Doc.lsp using a Load statement. Then try again.
    Another simple check at the command line is:
    Code:
    (if autoload T nil)
    HTH
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,515
    We have a Autoload.lsp on our server contians our user lisps. Loaded 2013 added support paths to top in CONFIG, 2013 found with no user intervention.
    So suggest pull all your lisps out of generic acaddoc2013 and make your own Autoload. I am sure others will advise if this is not right. Don't forget PGP also.
  10. #10
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    I too have an aptly named Autoload.lsp that contains Autoload statements for myriad routines, which itself is loaded by AcadDoc.lsp at drawing open.
  1. Express Tools in Civil 3D 2013
    By Tyke in forum Civil 3D & LDD
    Last Post: 17th Feb 2013, 06:03 am
  2. Replies: 2
    Last Post: 18th Jun 2012, 10:31 pm
  3. Civil 3D 2011 VBA Load Error
    By bschlang in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 27th Feb 2012, 11:39 am
  4. Conversion error from Pre Civil 2007
    By rossuwp00 in forum Civil 3D & LDD
    Last Post: 10th Jun 2010, 06:22 pm
  5. Will an AutoCAD 2004 upgrade CD upgrade Release 14?
    By kjsarchtech in forum AutoCAD General
    Last Post: 16th Sep 2009, 03:01 pm
