nila_joy Posted June 5, 2012 Share Posted June 5, 2012 Hi Guys, I am writing a routine in which the color of the linetype can change manually.. the routine will scan the whole drawing, and will findout how many types of "LineType" are using, and then it will change the color of the perticular line type the user will select. its working fine .. but how can I handle the linetype of blocks ? Is there any process availble to handle the linetype of blocks? Thanks .. subho India Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 5, 2012 Share Posted June 5, 2012 I presume that you are talking about the linetype of entities inside blocks - please check the routine from this previous thread. It will allow you to parse the componence of a block. Quote Link to comment Share on other sites More sharing options...
