Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    Quote Originally Posted by EnvisionMan View Post
    Whoa. How is that I've never seen anything that simple?
    Are there sites that give out these codes... where you can grab them and apply them to your drawing. This is wild.
    It would likely be an eyeopener for you to try the ALIASEDIT command, where, if you haven't done it previously you can customize all of your SHORTCALLS (command aliases).
    Set them so they make sense to you, it is your workspace after all.
    The life (time) you save may be your own!
  2. #12
    Full Member
    JGA's Computer Details
    WinXP
    AutoCAD 2008
    Jul 2007
    Scotland
    41
    If you have LT, the following macro works - "_Change P la 0;;" - I have it assigned to CTRL+ALT+NUMPAD0.
    I have CTRL+NUMPAD0 set to "^C^C-layer m 0;;" which makes the current layer 0.
  3. #13
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Should this be "^C^C-layer m 0;;" "^C^C-layer s 0;;" s for set rather than m "make" implies a new layer to be created Autocad doesn't return an error luckily using m. 2014 ?
  4. #14
    Full Member
    WinXP
    AutoCAD 2008
    Jul 2007
    Scotland
    41
    BigGal, you're probably correct, but the routine has worked from LT 2004 - 2013 (if it ain't broke, don't fix it!).
  1. Replies: 1
    Last Post: 7th Dec 2011, 01:17 pm
  2. House AutoCAD - Designing Walls and Doors HELP!!
    By NAILGUN in forum AutoCAD Beginners' Area
    Last Post: 12th Sep 2011, 11:01 am
  3. In 15+ years with AutoCAD I've never seen these. Now they're wreaking havoc!
    By PlutoISaPlanet in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Apr 2011, 01:12 am
  4. AutoCAD Action Recorder - 2 years later
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 29th Apr 2010, 09:00 pm
  5. 25 years of AutoCAD!!
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 16th Aug 2007, 08:00 pm
