Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Full Member
    AutoCAD 2009
    Jun 2010
    37
    Default trouble attaching dimensions to object in paperspace
    hi!
    i'm not sure if i'm doing this right. i have a little drawing in modelspace. in paperspace, i have a viewport. let's say it's set at 1/4" = 1'-0". everything looks okay so far.
    i click on the 'annotate' tab, and then select 'annotative' for my dimension style. it has the little triangle icon thingy so it should be annotative.
    i make a couple of simple linear dimensions on my drawing (still in paperspace). looks okay so far.
    but now lets say i want to change the scale of my drawing. i change it from 1/4" to 1/2" = 1'-0". my drawing gets bigger, but the dimensions stay the same size and position. they're no longer attached to anything on my drawing.
    then i change the scale again, let's say back to 1/4" scale. my drawing shrinks, but as soon as it's back to it's original size, the dimensions now suddenly get twice as big and are where they should have been at 1/2".
    and it continues like that, when i change my scale, the dimensions change to whatever the last scale was at, so that they're never synced up.
    what's going on, here?!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    There is no need to use annotative scaling if you are dimensioning in your layout instead of model space.
    Your dimensions should be set to "associative" which is NOT the same as annotative. This won't solve the problem if you change the viewport scale however. It will only help if you stretch an object and want the dimensions 1) to follow and 2) to update to the new size.
    If you constantly find yourself rescaling viewports then use Annotative Scaling but do so in model space not in paper space.
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Do you have DIMASSOC set to 2?
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Full Member
    AutoCAD 2009
    Jun 2010
    37
    hi!
    thanks for the quick replies...
    ReMark: i do find that i change viewport scales fairly often. i thought it would make sense to do all my annotations in paper space because then i can relate their size to the sheet of paper i'm printing on, rather than the size of the 1:1 model
    what i just noticed, is that i can't find my 'annotative scale' on the bottom right corner of my screen. i just have viewport scale.
    also if i select my viewport, and then also select the dimensions, the viewport scale says "VARIES" and then the button to the right of it says "ANNOTATIVE SCALE IS NOT EQUAL TO VIEWPORT SCALE - CLICK TO SYNCHRONIZE" and when i click that button everything straightens out. but do i need to select all my annotations first? can't i just change the viewport scale and have annotation scale sync up automatically?
    i'll play around with this in model space, and look more into dimassoc!
  5. #5
    Full Member
    AutoCAD 2009
    Jun 2010
    37
    my dimassoc is set to 2
  6. #6
    Full Member
    AutoCAD 2009
    Jun 2010
    37
    if i use the 'annotative' dimension in model space, here's what happens:
    1. a pop-up box pops up saying i'm about to create an annotative object, and to set the model scale. i chose 1:1 because that's the scale of my model.
    2. i create the dimension. it is TINY. i can barely see it on the screen.
    3. the dimension does not show up in my viewport in paperspace.
    that can't be right?
  7. #7
    Senior Member
    Manufacture
    eyde's Discipline Details
    Project Manager/ Regional CAD Manager
    Manufacture
    We manufacture concrete utility vaults
    AutoCAD 2011
    Sep 2010
    Southern California but a true Texan
    103
    While in model space change your scale to what your viewport scale is set. Your viewport and model space need to have the same scale.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    You set the annotative scale equal to the scale or scales your viewports(s) support. So if you plan on using three different scales for your viewports one option would be to set your dimensions to also use all three scales or some combination thereof.
    I do all my dimensioning and text in my paper space layout. I rarely, if ever, have to go back and rescale a viewport. If you are constantly changing viewport scales I would seriously reconsider your reason for doing so. Maybe your way of doing things is flawed.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    Everything is model space needs to be draw at FULL size. Your paper space layout viewports do NOT have to be the same scale as your model space. Only the objects like text, dimensions, blocks and hatches have to have the same scale as the viewport they will be displayed in.
  10. #10
    8GB
    280 GB
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Annotative scaling means that your dimensions automagically scale to whatever scale you set your viewport too - and it also doesn't show at any other scales.
    Instead of 1:1 like you did now, you set your scale on the dimension as 1/4" = 1'-0" is that is what you need. Now you need to have your viewport set to that scale (and the annotative scale on the viewport) as well, otherwise the dimension will not show.
  1. Attaching object to dimension
    By pBe in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jan 2012, 02:25 pm
  2. Automatically attaching object data by layer
    By randrews in forum AutoCAD Beginners' Area
    Last Post: 25th Nov 2010, 02:49 am
  3. trouble selecting an object drawn in paperspace
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Jun 2008, 04:46 pm
  4. Trouble attaching an XREF
    By C Tel in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2007, 07:02 pm
  5. Attaching object data from dwg to dwf?
    By darcys in forum AutoCAD Beginners' Area
    Last Post: 12th Apr 2006, 08:30 pm
