Call the SHAPE command with the options below:
Command: SHAPE
Enter shape name or [?]: ?
Enter shape name(s) to list <*>: *
We have a cad dwg that contains shape files, is there a command that will list all the shape files in the dwg?
Command: SHAPE
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
Thank you for the response.
I tried that and i got a window that said "no matching shapes found". Someone had me click the "data" icon in the task pane, "connect to data" and a window popped upwith a list of shp_#'s. When i select the title or try entering it, i get a "shape not found".
Are you using MAP 3D or Civil 3D?
Map 3d.....
I moved this to the Map 3D forum for you.
You will get better answers there.
With the map import the AutoCAD layers "may" give some idea as to the shape names, depending on who and what settings were used with the import. With FDO the display manager will list the data connections unless the map was saved to Auto dwg format in which case the autocad layers may have the shape or data connect name in them.
Murph
Need a boat or camper for the weekend?
