Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Junior Member
    AutoCAD 2008
    May 2012
    24
    So, now, i suppose Pbe won't ask me again to show my code . You like it, Pbe? The best code on the site!
  2. #12
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,090
    Quote Originally Posted by brams View Post
    Not at all brams
    The idea is ok, just needs fine tuning.
    Look into this _GetClosestTextTo sub-function: Renderman < post #6
    HTH
  3. #13
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,932
    Quote Originally Posted by MSasu View Post
    A little help, please... for a new autolisp user
    Seems to be what i'm searching for. Please, an example how to use your function together with ssget... to make 2 selection sets of points and texts, selecting objects only one time - i mean, a single "rectangle".
    @brams: What editor are you using? Seems that you pasted some control tags along AutoLISP code.
    Or did you tried to number the lines?!?
    I've copied the code that I previously linked here.
    Quote Originally Posted by pBe View Post
    FWIW
    Code:
    (defun c:sepsel ()
           (setq textsel  (ssadd)  PointSel (ssadd)
                  ss       (ssget '((0 . "POINT,TEXT"))))
                 (while (setq e (ssname ss 0))
       (if (eq (cdr (assoc 0 (entget e))) "POINT")
        (ssadd e PointSel)(ssadd e textsel))
                          (ssdel e ss)))
    Perhaps localized variables would be useful? Otherwise running the code multiple times would provide some interesting results.
    Cheers, Pbe
    "Potential has a shelf life." - Margaret Atwood
  4. #14
    Senior Member
    Structural
    AutoCAD 2011
    Sep 2011
    Baia Mare, Romania
    136
    Brams, this is what you need?
    Code:
    (defun C:PZ ( / *error* ss i en el p p1 echo)
      (setq echo (getvar 'cmdecho))
      (setvar 'cmdecho 0)
      (command "UNDO" "BE")
      (defun *error* (msg)
        (if msg (princ msg))
        (command "UNDO" "E")
        (setvar 'cmdecho echo)
      (princ "\nSELECTEAZA PUNCTELE SI TEXTELE")
      (if
        (setq ss (ssget '((0 . "TEXT,POINT") (8 . "Puncte,Cote")))) ; <- de modificat numele layerelor
          (setq en (ssname ss (setq i (1- i))))
          (if
            (setq z (cdr (assoc 1 (setq el (entget en)))))
              (setq p (assoc 10 el)
                    p1 (list 10 (cadr p) (caddr p) (atof z))
              (entmake (list '(0 . "POINT") '(8 . "Puncte") p1))
              (entmod (subst p1 p el))
            (entdel en)
      (*error* nil)
  1. Selection sets in vb.net
    By Jozi68 in forum .NET, ObjectARX & VBA
    Last Post: 14th Feb 2012, 07:33 pm
  2. VBA - Selection Sets
    By -KarL- in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Mar 2009, 10:54 am
  3. VBA - Using IF and selection sets
    By wannabe in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Oct 2008, 02:09 pm
  4. Little help on selection sets please
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 17th Apr 2006, 03:39 pm
  5. selection sets..........
    By rajanikrishna in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Nov 2005, 11:32 am
