Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Moving Profiles
    Senior Member DODGE's Avatar
    AutoCAD 2012
    Oct 2006
    Melbourne The land of Oz.
    445
    Default Moving Profiles
    Hi Guys
    I have always had problems moving my AutoCad profile from one computer to another.
    I have my AutoCad 12 set up with all my toolbars etc just how I like it and am used to.
    I had to move my profile to another computer the other day and I just couldn't get it to work.
    Can somebody give me step by step instructions on how to take it from Computer 'A' TO Computer 'B' and then just carry on using my template with my profile.
    Thanks in Advance guys.
    Dodge
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Just to be sure, when you say "AutoCad 12" you are referring to AutoCAD2012, not AutoCAD r12, correct?
    Assuming the former, workspace settings such as toolbars, aren't stored in the "Profile", they're stored in the CUI (cuix) Basically, anything that's a user "preference" such as Background colors, Osnap Settings, Crosshair size etc is stored in the profile. The profile also stores the paths to the support files/folders such as the location of your AutoCAD directory, template file location, and default template, font and linetype file location, AND the location of the CUI(s)
    The CUI (.cuix file) is where workspace settings are stored. This includes the arrangement of the Ribbon and toolbars, toolbar size and position, menus (both drop down and right-click) and custom commands, and their icons.
    Keeping that in mind, can you describe what type of problems you've had trying to re-use you settings from one computer on a different computer?
    AutoCAD 2012
    Oct 2006
    445
    Hi Nestly
    Yeh sorry I mean AutoCad 2012.
    I just want to transfer the exact same workspace settings, Ribbons, Toolbars etc etc onto another computer.
    When I open my template on Computer 'B' I want it to be exactly the same as computer 'A'.
    Note sure how to do this, do I just save these settings to a usb and then transfer to computer 'B'
    If this is the case what do I load to the usb and where do I find these files. Then I will need step x step how to load onto 'B' from the usb.
    Thanks for your help
    Dodge
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    I think I can get you set up after a few more questions.
    1) Have you made changes inside the CUI (CUI command) and if so, did you make those changes to the Main cui (acad.cuix) or the Custom cui (custom.cuix)
    2) When you say "template" are you referring to how AutoCAD looks when you first start it up, or the drawing (.dwt file) that loads when you first start AutoCAD.... or both?
    3) Do both computers have the same version of AutoCAD installed, ie both are vanilla AutoCAD 2012, or is one AutoCAD2009 and the other AutoCAD2012?
  5. #5
    AutoCAD 2012
    Oct 2006
    445
    Quote Originally Posted by nestly View Post
    Hi Nestly
    1 - As far as I know I have never made changes inside the CUI
    2 - When I first started using AutoCad I made a template, I set the dimensions, toolbars, blocks etc exactly how I wanted them. I have this template saved in a folder with shortcut to my desktop. When I start a new job I just double click this and save as..
    3 - Yes both computers are running same ver of AutCad 2012.
    I just want them set exactly the same but need a step x step how to find and save the files to a usb on computer ' A ' and then load on computer 'B'
    Many Thanks for your help
    D
  6. #6
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Based on that, I'm going to suggest you just exit AutoCAD and use the Migration tools in the Windows Start menu to export all your existing settings, put them on your USB drive, and then use the Migration tools on the new computer to "Import" your settings.
    Here's a good video that takes you the whole way through. (watch in full screen mode for better clarity)
    http://www.youtube.com/watch?v=GVYgh7vafXo
  7. #7
    AutoCAD 2012
    Oct 2006
    445
    Thanks Nestly
    This looks like the business i need.
    Thanks for your help.
    Dodge in Oz
  8. #8
    AutoCAD 2012
    Oct 2006
    445
    Hi Nestly
    Just watched the utube vid.
    Not sure if I am missing something, Under Autocad 2012 English. I do not have the Migrate Custom Settings option.
    Not on the Computer 'A ' or on the Computer 'B'
    Computer 'A' Is running Win XP Pro AND cOMPUTER 'B' is running Win 7 Home. Both computers with AutoCad 2012
    Dodge
  9. #9
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Look for a "Autodesk" folder in the Windows Start menu...
  10. #10
    AutoCAD 2012
    Oct 2006
    445
    Thanks Nestly
    I was looking in Windows explorer DOH!
    Feel like a D head.
    Cheers Dodge
  1. Profiles in AMEP
    By DIW_HDsupply in forum MEP
    Last Post: 23rd Mar 2011, 06:37 pm
  2. where is the Profiles tab in LT!
    By alijahed in forum AutoCAD Drawing Management & Output
    Last Post: 19th May 2009, 05:12 am
  3. Profiles
    By andrewjbarnett in forum CAD Management
    Last Post: 25th Sep 2008, 01:36 pm
  4. Profiles in LT
    By Starkey in forum AutoCAD Drawing Management & Output
    Last Post: 14th May 2007, 09:30 pm
  5. Profiles?
    By DANIEL in forum AutoCAD Drawing Management & Output
    Last Post: 16th Apr 2007, 04:15 pm
