Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Moving Profiles
  1. #11
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    You found them, cool. I thought you may have to install them since the Migration tools are an option during installation. I hope it goes real smoothly for you.
  2. #12
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Quick and dirty
    1 export out your profile
    2 make a copy of your cui its buried in document& settings\userid\autodesk\en etc
    3 copy these two files to your new computer somewhere easy, win7 say \users
    4 start autocad using default profile and import your profile set current exit autocad your profile should have the main cutomization menu path set to the same location as step 3
    5 make a copy of your desktop icon back to the desktop and click properties in the command line change the /p "toyourprofilename"
    6 start autocad all should work !
  3. #13
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Quote Originally Posted by BIGAL View Post
    Quick and dirty
    If I'm not mistaken, there will need to be a lot of manual repathing when importing a profile to Win7 that was exported from a WinXP machine because the directory structure is different.
  4. #14
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Nestly we use a server for most of our stuff so no local pathing, the other trick is we have a lsp for setting all paths etc we have 1 operator with a laptop so copied the lisp and made a couple of changes this set up his ARG which we save seperately to the normal one. As above we set our local paths high up in directories. I have posted before the setpaths.lsp will try to find this includes pointing to the correct cui location. We imported the 2012 ARG no problems. Ps the ARG is a text file so could edit that using search & replace.
  5. #15
    Senior Member DODGE's Avatar
    AutoCAD 2012
    Oct 2006
    Melbourne The land of Oz.
    445
    Quote Originally Posted by nestly View Post
    Thanks Nestly
    I thought I had replied, it all worked well did it all in about 2 minutes.
    Thanks Dodge
  1. Profiles in AMEP
    By DIW_HDsupply in forum MEP
    Last Post: 23rd Mar 2011, 06:37 pm
  2. where is the Profiles tab in LT!
    By alijahed in forum AutoCAD Drawing Management & Output
    Last Post: 19th May 2009, 05:12 am
  3. Profiles
    By andrewjbarnett in forum CAD Management
    Last Post: 25th Sep 2008, 01:36 pm
  4. Profiles in LT
    By Starkey in forum AutoCAD Drawing Management & Output
    Last Post: 14th May 2007, 09:30 pm
  5. Profiles?
    By DANIEL in forum AutoCAD Drawing Management & Output
    Last Post: 16th Apr 2007, 04:15 pm
