Results 1 to 6 of 6
    Forum Newbie
    Civil 3D 2012
    Jun 2012
    3
    Embarrassed Adding fields to polylines properties
    hi everyone
    Ive been trying to add additional fields to polyline properties... in the properties there are 4 fields...general, 3D visualization, geometry, and Misc.
    im trying to add additional fields to show more information
    Ive attached a picture to show what im trying to do...someone created "OD:wpipes" and "LT:wpipes" to show more information about the pline..how did they add those fields?
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    584
    The OD:Wpipes are from an MAP3D Object data table attached to the polylines. The LT:Wpipes are from a data base linked table also an Map3D function. The tutorials for map3d should provide you the info needed to create them.
    Murph
    Need a boat or camper for the weekend?
    Senior Member Emigrato's Avatar
    not applicable
    Sep 2011
    116
    In order to add your own fields to properties, first you have to define a new attribute table with _ADEDEFDATA then _ADEATTACHDATA - it works for me in Map2006, I hope in recent Civil too...
    Forum Newbie
    Civil 3D 2012
    Jun 2012
    3
    Smile
    Quote Originally Posted by Emigrato View Post
    thank you so much!
    i looked around alot for this and this is exactly what i was looking for
    again thanks alot!
  5. #5
    Forum Newbie
    Civil 3D 2012
    Jun 2012
    3
    Quote Originally Posted by Murph_map View Post
    thank you for replying
    ive never used map3 but what emigrato posted was exactly what i was looking for...im new on the job and i was supposed continue my predecessor's work which involved using OD for labeling utility lines...but thank you so much! is the linked table function available on civil 3D?
  6. #6
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    584
    Quote Originally Posted by falcon900 View Post
    Yes, the linked database table is part of Map3D and is in Civil3d, however there are a lot of issues with linking/connecting a database to newer versions of the civil/map3d. If you are using 32 bit vs 64 bit and the version of MS Office you have installed and with a linked template you only get the one field displayed in the property palette, were as in older version as simple drag & drop of the database file worked and you had all the fields displays in the property palette.
    Murph
  1. Custom properties / fields
    By goØn in forum AutoCAD General
    Last Post: 22nd Feb 2012, 02:27 pm
  2. Adding data/ properties to points
    By swimwsr in forum Civil 3D & LDD
    Last Post: 13th Sep 2011, 05:09 pm
  3. adding custom properties
    By orange in forum AutoCAD General
    Last Post: 22nd Jul 2011, 10:42 am
  4. adding data in fields
    By chelsea1307 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Nov 2009, 07:54 pm
  5. Adding the Layout Name via Fields to a Title Block
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 3rd Feb 2007, 02:40 am
