Results 1 to 5 of 5
    Full Member 19cruthik68's Avatar
    Electro/Mech
    19cruthik68's Discipline Details
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    AutoCAD link title of file to the title block inside
    I have a title block inside my drawing and i want to link my title on the title of the file itself, so that if the title of the file was change, it will be change also inside the drawing. how is this? thanks
    and so I did.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    You should look for a field (command FIELD).
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    AutoCAD 2013
    Nov 2011
    5,995
    Quote Originally Posted by 19cruthik68 View Post
    Mircea is right, this is pretty easily done by adding a field to your Sheet or Title Block. I will post again with visuals in a few minutes.
    You will want to double click on the text in the location where you wish to INSERT FIELD (from your right click menu), then set it up as shown in the image.
    This newly defined field will display the saved FILE NAME to the title block. I believe that is what you are trying to do?
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    thanks for the idea. it works already.
    and so I did.
  5. #5
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    I use something similar, but if you only want a portion of the filename (like I do), hen try a Diesel field. E.g. this would extract only the 4 characters from the filename, starting from the 3rd:
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  1. How to extract and link title sheet block attributes to spreadsheets
    By kheajohn in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2010, 11:46 am
  2. Title Block
    By monk in forum Tutorials & Tips'n'Tricks
    Last Post: 22nd Jul 2010, 08:54 am
  3. Title block
    By Happy55 in forum AutoCAD Beginners' Area
    Last Post: 14th Jan 2009, 05:23 pm
  4. Link the file name to parts/tags in the title block
    By Robert J in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2007, 03:34 pm
  5. Title Block
    By Cadgirl10 in forum AutoCAD Beginners' Area
    Last Post: 26th Jun 2006, 02:53 pm
Tags for this Thread
