Results 1 to 6 of 6
    Junior Member
    AutoCAD LT 2012
    Mar 2012
    16
    Default Relative Xref paths in New & Existing Drawings
    For new drawings, is there a way to program Autocad to always load Xrefs relative? We pretty much use xrefs everywhere, and it seems like it would save a lot of time if I didn't have to open the External References and change each xref to relative.
    Also, if you have an existing drawing and need to change the xref from absolute to relative path, is there a way to have it automatically do that? I'm assuming there isn't, but thought I'd ask.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,932
    When adding the XREFs to your drawing the user specifies relative path. If you need to revise multiple paths, and/or multiple drawings, consider Reference Manager.
    "Potential has a shelf life." - Margaret Atwood
    Junior Member
    AutoCAD LT 2012
    Mar 2012
    16
    Unfortunately AutoCAD LT doesn't allow me to access Reference Manager, as far as I'm aware of.
    Civil 3D 2011
    Nov 2009
    3,932
    Quote Originally Posted by acad2012 View Post
    If that is true; most unfortunate, as LT also precludes you from using LISP.
    Perhaps someone adept at the limitations of LT will know more, as I use verticals (i.e., Land Desktop, Civil 3D, Map 3D, etc.). Good luck!
  5. #5
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    AFAIK, Reference Manager should work with LT.
    What does SDI = ?
  6. #6
    Civil 3D 2011
    Nov 2009
    3,932
    Quote Originally Posted by SLW210 View Post
    That's what I thought (hence the suggestion in the first place! LoL), but do not have LT to verify.
  1. Full/Relative Paths and the ability to edit
    By slimjramirez in forum AutoCAD General
    Last Post: 17th Nov 2008, 08:59 am
  2. Xref Paths
    By hi-liter in forum AutoCAD General
    Last Post: 4th Nov 2008, 07:38 pm
  3. xref paths
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 27th Mar 2008, 06:29 am
  4. changing xref paths
    By yrnomad in forum AutoCAD General
    Last Post: 1st Mar 2008, 12:28 am
  5. Xref Paths
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 14th Aug 2007, 07:10 pm
Tags for this Thread
