Results 1 to 3 of 3
Thread: ipt to idw
    Forum Newbie
    Inventor 2013
    May 2012
    4
    Default ipt to idw
    how can i open an inventor file (ipt) as a idw file?
    sry if question is repeated
    Senior Member CAnnondale's Avatar
    AutoCAD 2009
    Apr 2009
    199
    Quote Originally Posted by kingkp123 View Post
    You need to create a new Drawing goto FILE>NEW>DRAWING. Then "PLACE VIEWS" the ipt file onto it.
    Thanks & Regards,
    Willie
    AutoCAD 2D/3D
    Autodesk Inventor 2012, Product Design Suite
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    I recommend that you first go through the Help>Learning Tools>Tutorials and Skillbuilders.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
