Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    AutoCAD LT 2000
    Jun 2012
    4
    Unhappy AutoCAD virgin in desperate need of help losing his cherry......
    Hi all,
    The reason I'm here, recently made redundant so started my own company, I used to have a drawing office but now its me or me!
    No money, so I could only afford AutoCAD 2000, I need to take drawings created by other people and import them to my own and then annotate them before submission to the client.
    All well and good except... I don't have the first clue how too!!!!
    I also need to produce my own border etc...
    I'm sure that this is bread and butter to the majority of members...
    My question, what is the most intensive (and cheap) method of learning the basic fundamental skills that will allow me to do the things that I have described above?
    I've tried Control C and then V in my own document but nothing came out, I've since used WBLOCK (found on here, thanks) and I now have a drawing in my own file, how do I get a border to fit it, how do I edit the details in the borders from the template folder. Good luck if you pick me to help.....
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,142
    Nothing like jumping into the deep end of the pool with an anvil for a float.
    AutoCAD LT 2000?
    Are you familiar with paper space layouts by any chance?
    Are you working in metric or imperial units?
    Do you have a name/logo for your company?
    What types of drawings are you producing?
    When you installed LT 2000 did you also install the service packs too?
    Forum Newbie
    AutoCAD LT 2000
    Jun 2012
    4
    Hi Mark,
    Anvil, that's about right...
    Paper space layout... somewhat, I think I make amendments in model and they are reflected in paper space? I guess that means no then!
    Metric, buildings in plan form only, very little detail, I just have to take an outline and show where I plan to install data outlets and containment routes.
    Yes, I do have a logo but can't seem to be able to edit the damn border detail...
    As mentioned, drawings are very simple line drawings, showing basic door openings, rooms and descriptions, I simply have to put a little detail on them, triangle for data and a number next to it showing the quantity of computer outlets and then an indication of the containment routes and sizes, all very easy... If only I could cut and paste the (expletive) drawing from the original that I have been issued with!
    I did install the service packs but (I think) they assume a degree of prior knowledge. I cant even find descriptions of the meanings for OSNAP, POLAR, ORTHO etc.
    Abject meppetry on my behalf I'm afraid....... (I can't even spell Muppetry!!!)
    Senior Member paisis123's Avatar
    paisis123's Computer Details
    WIN 7 PRO
    Cyperpower CUSTOM
    Gigabyte GA-870A-UD3 (Socket M2)
    AMD Phenom II X6 1055T
    8.0GB Dual-Channel DDR3
    ATI Radeon HD 6870 x2 (CROSSFIRE MODE)
    977GB GRAID SCSI Disk Device (SCSI)
    3 TB external segate drive
    3x ViewSonic VA2231w-LED
    Mechanical
    paisis123's Discipline Details
    Designer - Thermoplastic Extrusions
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    "nothing beats spending mindless hours experiementing on autocad"
    Did you try to make your own block?
    Do you know the difference of paper space and model space?
    Can you attempt to send us an example on what you are trying to accomplish?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,142
    You can get some immediate assistance by looking in your AutoCAD Help file. Next stop would be the User's Guide or a good aftermarket book such as "Inside AutoCAD 2000" by Bill Burchard and David Pitzer. It was published by New Riders.
    Re: paper space. This is where your title block and border would go along with any general notes. If you aren't completely conversant with this method you may find it difficult to wrap your mind around. Paper space was supposed to represent just that...your paper. One creates "viewports" in paper space to see the objects which were drawn back in model space. Model space objects would normally be drawn full size and not scaled like one would do if drawing manually on the board.
    Of course there is the option of doing everything in model space. You'll have to scale up your title block/border, your dimensions and text, then plot the drawing to a specific scale to get it all to fit on whatever paper size you had in mind for the finished product.
    Is your head still spinning?
    Can you attach a copy of your title block and border? Someone here can take a look at it.
  6. #6
    Junior Member
    MEP 2010
    Feb 2009
    11
    Hi Mark
    This is something i do a lot, do you have some blocks made of your data outlets?
    I am assuming you have like an Architects/Consultants drawing which has their frame around it?
    Not sure Wblock is the perfect option for you, can you up the original drawing file?
    If you inserted the drawing as a block you wouldnt be able to edit the frame unless you are able to explode it, i havent needed to do this before so not entirely sure i am accurate here
    OSNAP = Object Snap it creates points where you can snap say your triangle to a wall line at a point or intersect you can select end points and mid points of lines and various other options
    ORTHO = locks your drawing lines to horizontal or vertical plane
    Not sure you would need to worry about Polar just yet but ORTHO and OSNAP you should look into as you will use this regularly for what you seem to be doing
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,142
    OSnap does not create points. OSNAP is an object snap mode. Very handy for picking points, like the mid or endpoint of a line, to create accurate drawings. Other Osnap settings include center, perpendicular, parallel, nearest, intersection, quadrant, etc.
  8. #8
    Junior Member
    MEP 2010
    Feb 2009
    11
    Corrected, allows picking of points
  9. #9
    Forum Newbie
    AutoCAD LT 2000
    Jun 2012
    4
    jeeze,
    Methinks I'd best buy a book....
  10. #10
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Quote Originally Posted by samolea View Post
    jeeze,
    exicellent idea! remember to look up tutorials on youtube for basic skills as well!
  1. Replies: 4
    Last Post: 12th Dec 2011, 07:02 pm
  2. A bit of nest list virgin - Probably fairly simple question
    By Hudson in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Oct 2009, 03:12 pm
  3. Cherry Tree
    By blair in forum Catch All
    Last Post: 29th Mar 2009, 08:53 pm
  4. Imperial Virgin Needs Advice
    By Boro Nut in forum AutoCAD General
    Last Post: 29th Sep 2008, 11:00 am
