If a layer is truely not being used, it will be displayed as a layer that can be purged using the PURGE command.
I have a drawing that has many layers in it. many of witch are not being used. Is there a way to quickly find out which layer are not being used in the drawing so i can delete them?
Open the layer manager, the first column is Status, if it is grey it is not being used, if it has a color, mine is light blue, then it is being used. You can pick on the Status header and sort by used and not used.
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
I can't say for certain about AutoCad2010, but I believe that feature is disabled by default (ie all layers show light blue, whether they're used or not)
SHOWLAYERUSAGE = 1 via the command line, or the checkbox in the Layer Properties Options dialog box to enable it. I think it's "Off" by default because it's a resource hog.
Stubborn layers that just won't go away using the PURGE command can be deleted using Layer Delete found under Format > Layer Tools or via the command line using LAYDEL.
You could also use the Layer Merge command as well.
