I have a drawing that has two different floor elevations on the same drawing. I need to have two different BOP tags so that they show up correctly. I tried making a new formula in the PipeObject in the style manager. It is basically the stock bottom of pipe calc with -3'5 1/4" after it, but it doesn't change the test at all. When I put 10 feet into the test thing, it still reads 10 feet instead of the lower number. Is there a way I can get this to work.
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
Did you ever figure this out? Just checking back in is all. I posted this on my phone while on vacation so I didn't go into much detail.
You should read the solution I posted in your other thread found here: http://www.cadtutor.net/forum/showth...ting-BOP-Label
It should hold the solution for you.
