Page 2 of 21 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 209
  1. #11
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    Tests are done, now i have to complete the project to finish the course. The timing conflicts with my tuition reimbursement. My company is a multi-billion dollar company that just keeps taking from customers and their employees. I am in the very beginning. Table 2. I think i skipped the plot size, and a couple of other things. I hope it works out. I didn't even figure out the scaling. Anyways, i am new to this and i am a truly hands on learner, so if there are no video lessons then i am screwed. Lol
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,084
    Table 1 is setting up the layers and Table 2 is for setting up the Text Styles. That's as far as you have gone (page 4 out of 21)? Not much progress being made. You have the entire drawing to do which is setting out the street lines, lots, existing and proposed trees, and all the labeling not to mention the title block and border. I'd get a move on if I were you.
    There are no videos for the Penn-Foster projects that I am aware of.
  3. #13
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    So I am trying to figure out the Tree block part, I already messed up the drawing parameters but I hoped to fix that later. Am I suppose to actually draw a tree or is there an object I can select from the menu?
  4. #14
    Junior Member
    AutoCAD 2010
    May 2011
    22
    You actually draw the tree and save it as a block. Then insert the trees at the coordinates they give you.
  5. #15
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    wow, you would think having a bachelor's degree (justice and law) at a state school would help me understand autocad easier. I just don't get it. I am trying to draw the lines from page 4 and 5, and I still can't get it right. I have literally spent about 6 hours trying to get through the basics. I need a tutor fast. It has hard to understand exactly what am I suppose to type, especially when everything is from text. There was no classroom time for this, and I have become very desperate to get this project done. Can anyone help? I type @113.66<N5D27'23"W.....then what? the line is not staying where it is suppose to. I then have four more points to draw. I cant even figure out how to get the ribbons on top of my autocad page. This is crazy. I have two jobs, three kids, and a nagging wife. I am losing my cool.
  6. #16
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    Remark, how much for your time? I can't pm you for some reason.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,084
    If you have a command line you can try typing the word RIBBON then press ENTER.
    Re: drawing property lines using direct distance entry. Start the line command. Pick your first point (probably the endpoint of a previously drawn line) then type in the angle and distance just as you have done. AutoCAD should draw the line correctly. Then draw the next line the same way.
    I'm assuming you have properly set your angle input to surveyor's units via the UNITS dialog box. Precision should be set to N0d00'00"E.
  8. #18
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    When I input the numbers and hit enter, I move my mouse and the whole lines just moves around. The line is not staying exactly where I inputted the property line points according to page 6.
  9. #19
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    No tabs or panels are loaded. any suggestions on which ones I should load? sorry about this. I'm glad you have the patience for these things, because I have run out of steam. lol
  10. #20
    Full Member
    AutoCAD 2010
    Jun 2012
    Norwalk, CT
    90
    are we able to chat via a im? or is that a lot to ask? yahoo? or something?
  1. Penn Foster Oleson Village Project Check
    By Batman in forum Student Project Questions
    Last Post: 27th May 2012, 02:27 pm
  2. Penn Foster Oleson Village, Please Help
    By millerrk in forum Student Project Questions
    Last Post: 8th Dec 2011, 01:47 pm
  3. need project help for penn foster oleson village
    By Firligic in forum Student Project Questions
    Last Post: 9th Aug 2011, 07:30 pm
  4. Penn Foster Oleson Village project
    By bracken2 in forum Student Project Questions
    Last Post: 1st Aug 2011, 04:07 pm
  5. Penn Foster Oleson Village drawing
    By black31 in forum Student Project Questions
    Last Post: 16th Dec 2010, 10:56 pm
Tags for this Thread
