Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie Jimbo_Jet's Avatar
    AutoCAD 2013
    Jun 2012
    7
    Default Poor 3D performance with Quadro 2000
    Hi, thought I'd try here for help as Nvidia appear to be useless at helping me.
    I have a new Quadro 2000 which in 3D Autocad performs no better than the Geforce 9600 GT it replaces, but in 3dsMAX the viewport frame rate has rocketed as it should.
    As far as I can tell Nvidia do not make an AutoCAD performance driver for this card, which is plain ridiculous!
    To test this I had a CPU and GPU monitor running while using 3DOrbit in various view modes on AutoCAD and 3dsMAX with a very large file open in each. In AutoCAD one core of my quad core processor runs at 100% (25% of total) and the GPU around 0-5% while rotating the model and the display frames per second is less than 5 or just unusable. This is no better that the 4 year old 9600 GT it replaced. AutoCAD is still a single core application in the main so this tells me that the GPU is just not being utilised correctly and a single core of the CPU is doing all the work.
    In 3dsMAX a similar file now uses 70-100% CPU but 100% GPU load while rotating and I'm getting 85+ FPS which is ideal.
    Has anyone had this problem?
    I've tried dozens of different drivers, re-installs and clean installs but nothing has worked for AutoCAD. An no one on the nVidia forums has a solution but I'm far from the only one with this problem with the new range of Quadro cards.
    Thanks!
    Full Member
    AutoCAD 2009
    Jan 2009
    57
    It's not a problem, but AutoCAD' s design flaw - new gadgets, old slow and made for 2d core!
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Nvidia has claimed that Autodesk has removed support for a "performance driver" in AutoCAD2012, therefore they haven't developed them. Silly question, but I'll ask anyway..... Hardware Acceleration enabled?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    Have you gone through the nvidia control panel, picked AutoCAD and then tried different settings?
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  5. #5
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    Have you tried the latest driver from Autodesk? Drivers
  6. #6
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    I merged your 2 threads and moved to Hardware & Operating Systems forum.
  7. #7
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,948
    For those who look to this thread prior to purchasing, I spec'ed out our new computers, and they're working great:
    Dell Precision M6600, Windows 7 64-Bit, Intel [Quad-]Core i7, 16 GB Ram, 2 GB Nvidia Quadro 3000M
    ... Using Land Desktop 2009, Civil 3D 2011, Map 3D 2011, Civil 3D 2012, AutoCAD MEP 2012, etc.
    "Potential has a shelf life." - Margaret Atwood
  8. #8
    AutoCAD 2013
    Jun 2012
    7
    Quote Originally Posted by nestly View Post
    Thanks everyone for the quick replies!
    Yes I understand since 2012 something like that has happened. Crazy thing is when you go to the nvidia driver page and look for the autocad performance driver for the Quadro 2000 there isn't one. But there is for the Quadro 4000 albeit for AutoCAD 2011. Have tried installing that instead but it won't let me. If I could get it to install I would change my 2013 licence to 2011 do I could use it. Also, ype hardware acceleration is on but thanks for asking.
  9. #9
    AutoCAD 2013
    Jun 2012
    7
    Quote Originally Posted by rkent View Post
    Yep tried that as well but no joy. But there is no setting for AutoCAD, just Autodesk Mudbox or Motion Builder?
  10. #10
    AutoCAD 2013
    Jun 2012
    7
    Quote Originally Posted by SLW210 View Post
    Yep, several times including driver removal tools and fresh installs.
  1. Quadro vs Geforce in terms of AutoCAD performance?
    By jitindhillon in forum Hardware & Operating Systems
    Last Post: 27th Aug 2012, 06:37 pm
  2. PDF in ACLT 2012 poor performance
    By netman in forum AutoCAD General
    Last Post: 4th Mar 2012, 04:33 pm
  3. Quadro FX 2000, VBA enablers = slow cursor
    By Blam in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 3rd Aug 2011, 03:06 pm
  4. New Hardware produces poor SolidWorks performance
    By sanderson in forum SolidWorks
    Last Post: 2nd Nov 2010, 11:06 pm
  5. gtx--> quadro fx
    By Viktorik in forum Hardware & Operating Systems
    Last Post: 15th Mar 2010, 01:46 am
