+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Mar 2010
    Posts
    76
    Question AC2012 layout print & Designjet T2300. D size incorrect print rotation.
    I have a template with layouts of different sizes that had been working fine with a previous Xerox 6204. My D size and E size automatically oriented with the 36" side parallel to the roll feed. I have since moved to a job that got a Designjet T2300. On this machine the D size orients the 24" side parallel. This wastes 1' of paper on the left and uses 1' extra as it runs the 36" side perpendicular. I have been unable to rectify the problem. I have tried printing in portrait, that actually cut off some of the image. I have tried all types of rotation within the driver and layouts. Tech support had me going into the machine settings and set rotation to 90. Nothing. There is a warning that "HP utilities" is not installed. Could this be a remedy? When the tech came to set up the printer he installed the necessary drivers but mad no mention of this utility.
    Hoping someone here is familiar with this problem. AC2012, HP desighjet T2300
  2. #2
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,780
    Default
    You need the HP software installed and there is options like autorotate and save white space, a crude way while your waiting try rotating your title block 90 deg and plotting using a portrait size sheet
Similar Threads
  1. Cannot Print Colour, Crunched up Text, Restricted Print Field
    By D1-Xen in forum AutoCAD Drawing Management & Output
    Last Post: 14th May 2012, 06:46 am
  2. Print to PDF without the layout name?
    By cadman6735 in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Dec 2010, 04:19 pm
  3. Reduce size of .idw to print
    By linnmaster in forum Autodesk Inventor
    Last Post: 5th Mar 2010, 01:14 am
  4. How do I display actual print size
    By jeffd24 in forum AutoCAD Beginners' Area
    Last Post: 3rd Dec 2008, 09:43 pm
  5. print as real size
    By evolvor in forum AutoCAD Beginners' Area
    Last Post: 6th Jun 2006, 08:56 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
