ShadabKhan Posted June 14, 2012 Share Posted June 14, 2012 When I move any object using move command then dimensions are move with objects but dimensions are stretch and show as long extension line in the drawing. I have checked DIMASSOC it is set to 2. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 Try DIMREASSOCIATE. You might also want to try remaining calm too. This isn't a case of life or death. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Dear ReMark, I got a drawing from other and i have to submit that drawing by evening but i am facing this problem. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 OK...it is a problem. I understand that. But remaining calm is in your best interest. A clear head can accomplish much. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 I have checked all System Variable related to DIM they all are set to there initial value. when i am using AutoCAD 2010 there is no Problem but when i open that drawing on AutoCAD 2013 this problem is generate. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 So you are using 2013 not 2012 like your profile says. Interesting. Attach a copy of the DWG file to your next post. Someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Ya I am using AutoCAD 2013 today i will update my profile. some of my files are showing EDUCATIONAL Stamp how to remove this from my drawing. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 14, 2012 Share Posted June 14, 2012 By definition Objects that are entirely enclosed by a Stretch selection window are moved, and objects that are only partially enclosed by a Stretch selection window are stretched, therefore in order to "move" the Dimension and extension lines with the STRETCH command, the Dimension line must also be included in the Stretch window. Quote Link to comment Share on other sites More sharing options...
samchums26 Posted June 14, 2012 Share Posted June 14, 2012 Ya I am using AutoCAD 2013 today i will update my profile.some of my files are showing EDUCATIONAL Stamp how to remove this from my drawing. saveas to dxf and save it again to dwg. Maybe there's another way to do it. Just wait for another replies from our friends here Quote Link to comment Share on other sites More sharing options...
nestly Posted June 14, 2012 Share Posted June 14, 2012 .some of my files are showing EDUCATIONAL Stamp how to remove this from my drawing. Some or all of the content in those drawings was created with an Autodesk product that was intended to be used ONLY for Educational purposes. Attempting to remove it is illegal, regardless of what type of license you have. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Dear ReMark, There is no option to attach file. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Dear Sam, I have bulk of files one by one if i will do this it will take lots of time. I think Autodesk Provides some LISP Routine for it. i am searching that LSP file but i unable to find. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Some or all of the content in those drawings was created with an Autodesk product that was intended to be used ONLY for Educational purposes. Attempting to remove it is illegal, regardless of what type of license you have. We are Autodesk Re seller. I have sold Commercial Licence to my customer and he is facing this problem becoz some drawings he got from other consultant might be possible his consultant is using EDUCATIONAL VERSION. Now my client want the solution of this Problem do have the Solution. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 The OP states that he moved the object. I see no mention of the word "Stretch". Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 Dear ReMark, There is no option to attach file. Start by clicking on the "Go Advanced" button. Look for the Paperclip icon. Upload and attach a drawing. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 The OP states that he moved the object. I see no mention of the word "Stretch". Hi ReMark, How to attach file with quote i unable to find. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 14, 2012 Share Posted June 14, 2012 See my previous instructions. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 14, 2012 Share Posted June 14, 2012 If you're an authorized Autodesk reseller, you should already know both the technical and legal answer to the Educational version plotstamp issue. Autodesk will provide assistance provided there isn't abuse of their licensing agreements, so I recommend you contact them directly. Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 Hi ReMark, How to attach file with quote i unable to find. I have attached file kindly find and try to move the object you can see dimension stretch. IPDM-E-L-010-DWG_ 00.dwg Quote Link to comment Share on other sites More sharing options...
ShadabKhan Posted June 14, 2012 Author Share Posted June 14, 2012 If you're an authorized Autodesk reseller, you should already know both the technical and legal answer to the Educational version plotstamp issue. Autodesk will provide assistance provided there isn't abuse of their licensing agreements, so I recommend you contact them directly. I have wrote mail to Autodesk Technical Team they will send me that LISP Files i dont know when they send me but i need help today..... Quote Link to comment Share on other sites More sharing options...
