Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Junior Member
    AutoCAD 2012
    Jun 2012
    20
    Smile Laying switches sockets on walls.....quickly
    I want to know how do professionals lay the switches and sockets at pre defined distances from reference points on large scale drawings?
    hopefully the answer will teach me more about placing objects quickly by using lesser no of steps.
    for clarity please go through the attached image.
    thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    The switches and sockets are blocks? If so, what if the insertion base point was equal to the fixed distance required?
    A dynamic block might even be better.
    Junior Member
    AutoCAD 2012
    Jun 2012
    20
    I guess I need to clarify .... I have blocks of switches and sockets etc and I need to put switches at say 20 cm from the door ......not all but a majority of them. similarly i have sockets to be placed at varying distances from doors or corners etc.
    I want to know what is the quickest method of placing objects (like switches) with respect to a reference point. The object can be anything, i just want to know the professional method.
    i am currently copying the object at the reference point and then moving it by entering the distance. which is obviously not the correct method....
    please help
    thanks
    Senior Member
    Architecture 2011
    Dec 2010
    172
    Make sure that the insert point of the block is somewhere sensible. In the case of this switch use the centre of the circle part of the symbol.
    Use this same point as the base point of your copy, or if you're inserting the block it's the "base point" already.
    Use TRACKING or FROM snapsto place your switch relative to other points.
    dJE
  5. #5
    Junior Member
    AutoCAD 2012
    Jun 2012
    20
    Quote Originally Posted by danellis View Post
    dJE
    I request you to kindly elaborate on it further.
    Just want to quickly put a switch 20 cm from the door ..... forgetting the blocks part...... lets say its just one switch only. what is the quickest method...... probably by direct distance entry....... dont know exactly how.
    please guide
    thanks
  6. #6
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Yes, OSnap tracking and Direct Distance Entry is the fastest way to locate objects a known distance from a corner, but you may also consider placing additional point parameters in blocks to quickly snap them into the desired position. See demo below
    http://www.screencast.com/t/ZeHgdgCY
  7. #7
    Junior Member
    AutoCAD 2012
    Jun 2012
    20
    Quote Originally Posted by nestly View Post
    Thanks a lot once again for the superb explanation.
    a couple of doubts remains, one that do we have to use insert command for each individual switch or is there a way out for say 50 switches in a plan....
    secondly, if it was not a block and i just wanted one particular switch to be shifted say 20 cm from a reference point... will the otrack still work. I tried that but it didnt work...... i used move and copy both.....none worked with otrack.
    thanks once again.
  8. #8
    Forum Newbie
    Architecture 2008
    Apr 2008
    1
    Wow, very nice!
  9. #9
    Senior Member
    Architecture 2011
    Dec 2010
    172
    That's pretty nifty, nestly (sorry, couldn't resist), I've never had the opportunity to do much playing with dynamic blocks: that's really nice.
    dJE
  10. #10
    Senior Member
    Architecture 2011
    Dec 2010
    172
    I would probably put my first one or two blocks in using the insert command (if you just hit <ENTER> or the <SPACEBAR> it repeats the previous command, so this is actually quicker than one might imagine, similarly you can just hit ENTER again to specify the same block), but after that would probably use COPY instead. INSERT can be useful because of the option to specify rotation on screen - that could be very useful in the case of placing switches.
    There are, though, other ways of inserting multiple blocks. If you had to place a switch every five meters over a 250m long corridor (bloody long corridor, but it serves an example) you might want to look into the ARRAY or MEASURE (MEASURE would be useful if it were a curved corridor, or one that went round corners) commands. If you need 50 switches equally spaced over a 350m corridor you might want the DIVIDE command. Obviously these are pretty extreme examples...
    dJE
  1. Replies: 2
    Last Post: 30th Mar 2012, 12:28 am
  2. Arrow switches to arch tick
    By j_spawn_h in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 20th Oct 2011, 01:50 pm
  3. AutoCAD switches drawings by ITSELF! :o
    By DWG Destroyer in forum AutoCAD General
    Last Post: 23rd Apr 2010, 05:19 pm
  4. Removing under laying objects
    By muck in forum AutoCAD General
    Last Post: 5th Aug 2009, 02:00 pm
  5. Plugins for drawing cavity walls, party walls etc.
    By LukeR in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2007, 08:24 pm
