+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    66
    Default UNION a 3D Text and a 3D object in CAD2012
    I want to make a UNION of a 3D object and 3D Text, but Union Command doesn't work! Any suggestions!
    PS- Attachment includes dwg file
  2. #2
    Super Member
    Computer Details
    nestly's Computer Details
    Operating System:
    Windows XP Professional (32bit)
    Motherboard:
    Intel DG33FB
    CPU:
    Intel Core2 E2220 @ 2.4GHz
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    250GB WD 7200rpm / 320GB WD 7200rpm
    Secondary Storage:
    500GB WD external USB
    Monitor:
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    You can't union blocks, but I have no idea what you did to make those letters unexplodeable anonymous blocks.
    *edit* non-uniform scaling is why the individual letters could not be exploded.
  3. #3
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    66
    Default
    Thanx fr your reply! The 3D text created is not block. I made it through AppLoad>3DText
    I could easily explode it though! (See attachment), but once again exploded text can't get unioned with the box!
  4. #4
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    Yes, the word "3D TEXT UNIONED" is a block. Inside that block, each letter is it's own block. Inside each letter is a solid, and a solid hatch. Each of the letter blocks is scaled non-uniformly, and therefore can not be exploded until the XY and Z scaling is normalized.
  5. #5
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    3D Text Lisp
    http://cadtips.cadalyst.com/create-text/3d-text
    The top tip of this month is 3DText (Tip #2081) from Aaron Werning. This fantastic tool adds depth to a text object so it shows up nicely in a 3D drawing. Instead of creating text objects 3DText generates a series of polylines in blocks that trace the text characters and have a z depth. To use this program, load the LSP file and type 3DTEXT at the AutoCAD Command prompt. Press Enter to start the creation of a new 3D text graphic or select an existing 3DText object for edit. You must use the 3DText command to edit the text in the 3D text graphics. Each text sequence is stored as a block and each character is drawn as a block behind the scenes.
  6. #6
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    66
    Default
    I see your point. But I didn't add them as a block. As I said earlier, I used AppLoad> 3d Text The text created would behave as a block though! If you have some other ideas to create the 3D text in CAD,plz let me know. The goal is to make a unioned feature from
  7. #7
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    The 3D Text lisp made it into block(s), that's how it works (see above)
    You can still use what the lisp created for a Union operation, you just have to exploded it down into Solids again.
    The entire procedure is shown below (watch in full screen for best results)
    http://www.screencast.com/t/DkXzHmFxmJWd
  8. #8
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    66
    Default
    Thanks a lot for the screenshot. I followed your steps and it worked well!
    But I don't know why I couldn't make it for another example! The only difference was the height of 3D Text. I most likely missed sth! plz take a look at the screenshot http://www.screencast.com/users/CAD_...d-f8966d99c2c6
    PS- dwg file enclosed.
  9. #9
    Super Member
    Computer Details
    Operating System:
    Motherboard:
    Intel DG33FB
    CPU:
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    Secondary Storage:
    Monitor:
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    The 2nd explode operation partially failed because all the letter blocks were scaled X=0.2 Y=0.2 Z=0.04. The X,Y, and Z scaling must be equal before exploding a block containing 3D objects. The hatches separated from the block, but each of "letters" remained a block.
  10. #10
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    66
    Default
    Got it! Thanx again for your help!
Similar Threads
  1. Lisp in Startup Suite Causing Slow Save and Close - Cad2012
    By pardavis in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2012, 12:51 pm
  2. Problem with hatch in cad2012!
    By codered8x in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 1st Apr 2011, 08:38 am
  3. Move a "union"-object to exact coordinates
    By julaftonsful in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jan 2010, 02:36 pm
  4. 3D object union
    By dbUT in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Feb 2007, 05:47 pm
  5. How to union 3D object from 2 different plans???
    By dreamid in forum Tutorials & Tips'n'Tricks
    Last Post: 4th Jun 2004, 01:24 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
