Results 1 to 4 of 4
Thread: Workspace
    Full Member
    Civil 3D 2010
    May 2010
    Central valley (California)
    49
    Default Workspace
    We are going from XP to Win7 shortly. This means re-installing our C3D. Is there a way to save our Workspace settings to our network so we don't have to go thru the hassle of putting everything back together piecemeal?
    Thanks,
    D
    Reality is just a hallucination brought on by the lack of alcohol.
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    MEP 2013
    Sep 2010
    1,977
    If you're only concerned about the "workspaces" you need only copy any .cuix files you've modified. After you've installed AutoCAD on the new machine, simply replace the OOTB (out of the box) .cuix files with those from your existing machines.
    If however, you want your drafting settings, background colors, crosshair size, etc to be transfered to the new machines, you also have to copy over profiles. If you're simply going from C3D 2010 to C3D 2010 on a different machine, I personally suggest you use the Migration wizard as shown in the video below
    http://www.youtube.com/watch?v=GVYgh7vafXo
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Dont forget if your using a custom profile to make a copy of the new Autocad desktop icon and change the /p yourprofile to point to your profile. To make life easy we put the cuix and arg into \users makes any changes to the config paths easy did this prior to changing to new box.
    Full Member
    Civil 3D 2010
    May 2010
    49
    Thanks nestly. That particular youtube video is for the 2012 version and not available on 2010 but I did look up "migration" in my help section and I believe there is enough info to get it done. If not, then I will be back with questions. IF they pull the trigger on getting the upgrade that is.
  1. Workspace
    By WOJR in forum AutoCAD Beginners' Area
    Last Post: 11th Aug 2011, 07:46 pm
  2. Replies: 1
    Last Post: 1st May 2011, 11:44 pm
  3. How to get the workspace like that ?
    By khuduba in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Sep 2010, 10:47 am
  4. 3D workspace
    By robertorres29 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2008, 06:01 pm
  5. Workspace
    By CADgirl in forum AutoCAD Drawing Management & Output
    Last Post: 12th Nov 2007, 11:18 pm
