ScriptPro for AutoCAD has been around for many years and for those that have tried it, it is a very valuable time saving free tool. ScriptPro is used to batch process files in AutoCAD using a script so perhaps a minor edit to DWG files such as adding company standard layers, a stamp, a title block, audit and repairs and much more.
ScriptPro for AutoCAD is free and now available in both Windows 32bit and 64bit for 2008 and up releases of AutoCAD based products. The tricky part which I answered in a blog post comment this week is that the 32bit and 64bit versions are located in two places as the 64bit version is actually on Autodesk Labs plugin of the month as it had to be re-written from scratch for the new platform while the 32bit version is in the standard AutoCAD Migration Tools downloads.
Download ScriptPro 32bit and 64 bit for AutoCAD 2008 and later.
ScriptPro 32bit download now
ScriptPro 64bit download now Just extract and then copy the bin folder and run ScriptPro. It also includes the source code.
  • Autodesk Customization Conversion Tools
    Convert your customized menus, files, command aliases, and layer states, and script with greater ease.
  • DWG TrueView (Includes DWG Convert) – FREE
    View and convert any AutoCAD or AutoCAD-based drawing file for compatibility with any version of AutoCAD between AutoCAD Release 14 and the current version of AutoCAD, This free download no longer requires AutoCAD to be installed to run.
More...
