Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2012
    Jun 2012
    2
    Default arcs not smooth when 3D rendering
    i have a problem when rendering 3d objects having arcs.
    the arc in the rendered photo is not smooth and round !
    please help!
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    How far are you from the origin?
    Facetres=?
    Have you drawn at 1:1 scale and correct units.
    http://www.cadtutor.net/forum/showth...ple-flat-faces
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    AutoCAD 2012
    Jun 2012
    2
    distance from origine around:30000
    facetres=1
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,041
    Try setting FACETRES system variable to the maximum value permitted (10).
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  5. #5
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,588
    Also turn Dynamic Tessellation to OFF.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  6. #6
    Full Member FernandoLucchesi's Avatar
    FernandoLucchesi's Computer Details
    Windows 7 (x86)
    ASUS M2N68-AM SE2
    AMD Athlon II X3 425 @ 2.9Ghz
    4Gb
    GeForce GTS 250 (1Gb)
    SAMSUNG HD204UI, 2Tb
    Philips 190CW 19"
    Civil
    AutoCAD 2010
    May 2012
    Sao Paulo, Brazil
    33
    It's something weird, because it seems like the window's ledge is rendering round and smooth, or i could be wrong...
    "Veni, vidi, vici..."
  1. Arcs and circles are no longer smooth.
    By nicnicman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Aug 2012, 05:04 pm
  2. Smooth out arcs and circles in 3ds
    By nocturne00 in forum 3D Modelling
    Last Post: 3rd Aug 2009, 06:08 pm
  3. adding windows to arcs and misshappen arcs?
    By damob23 in forum 3D Modelling
    Last Post: 16th Jul 2008, 12:52 pm
  4. Can anybody help rendering tobe sharp and smooth
    By Davidnor in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Oct 2007, 03:49 pm
  5. Replies: 0
    Last Post: 12th Sep 2006, 08:57 pm
Tags for this Thread
