Results 1 to 9 of 9
    Forum Newbie
    Allan siriba's Computer Details
    Windows 7 -64 bit
    Dell vostro
    i7
    8gb ram
    1gb nvidia graphics card
    500 gb hard disk
    Civil
    Allan siriba's Discipline Details
    Civil engineer
    Civil
    Civil 3D 2012
    Jun 2012
    4
    Default Datum transformation
    I have just finished designing a 56km road. On completion we have been asked to tie the road to the national grid used by our local authorities. My coordinate system is WGS84 and the national grid is ARC 1960. The xyz shifts, given by the surveyor, between the two coordinate systems in WGS84 are δy=-63.447 δx=-13.931 δz=-0.232. I have tried having a geocentric translation on civil 3d 2012 but to no avail. What would be the simplest approach to applying this shift without having to start from scratch?
    Senior Member Emigrato's Avatar
    not applicable
    Sep 2011
    116
    Well, did you just try simply:
    1] _MOVE
    2] select all
    3] as source point, type in 0,0,0
    4] as destination point, paste -13.931,-63.447,-0.232
    Forum Newbie
    Windows 7 -64 bit
    Dell vostro
    i7
    8gb ram
    500 gb hard disk
    Civil
    Civil engineer
    Civil
    Civil 3D 2012
    Jun 2012
    4
    I did try move but my existing ground levels on my profile views were all messed up and the corridor wouldn't budge. Having said that move still feels like the most viable option.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    987
    Have you tried redefining the coordinate system for the drawing itself?
    breaking AutoCAD on a regular basis since 1991
  5. #5
    not applicable
    Sep 2011
    116
    If you don't wanna physically move your objects, what about shifting your UCS origin..?
    1] command _UCS
    2] type in _OR
    3] paste -13.931,-63.447,-0.232 as new origin.
    I know that's a dirty trick, but...
  6. #6
    Forum Newbie
    Windows 7 -64 bit
    Dell vostro
    i7
    8gb ram
    500 gb hard disk
    Civil
    Civil engineer
    Civil
    Civil 3D 2012
    Jun 2012
    4
    How do i redefine the coordinate system? or does redefining the coordinate system involve editing the drawing settings and transforming a reference point? I have tried that but it does not reflect.
  7. #7
    Forum Newbie
    Windows 7 -64 bit
    Dell vostro
    i7
    8gb ram
    500 gb hard disk
    Civil
    Civil engineer
    Civil
    Civil 3D 2012
    Jun 2012
    4
    Shifting my UCS origin seems to work for my grids but it does not reflect on the profile views and the alignment details. For example the coordinates for the start and end of my curves do not change and are still WCS coordinates. My profile views also do not reflect the delta z change.
  8. #8
    Windows XP Pro
    Dell Optiplex 330
    Civil
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    987
    Quote Originally Posted by Allan siriba View Post
    Open the Settings tab of Toolspace. Right-click on the drawing name (first line). Select "Edit Drawing Settings." On the "Units and Zone" tab, you can define the zone category and the coordinate system for your area.
    If that doesn't work (and I suspect it won't), you'll have to physically move your objects. The surface(s) may take a little extra work, but there's a utility for that. The profiles and corridor should move dynamically with the objects you used to define them, or you'll have to recalculate/rebuild them (not re-create them).
    Profiles work off the World UCS. At least, I don't know of any way to change that.
  9. #9
    Full Member
    Civil 3D 2011
    Aug 2011
    99
    I would do the move in the X and Y coordinates only.
    Then I would use the Civil 3D tools to move the surface and any profiles by -0.232
    I would not recomend changing the UCS origin. Civil 3D starts acting very strange if you are not in UCS WORLD.
    You have a rather easy move to do, as you have a defined movement, and do not ahve to SCALE anything.
    We are always having troubles between Ground and Grid Co-ordinates.
  1. 2 datum surfaces in 1 corridor
    By sandiegophil in forum Civil 3D & LDD
    Last Post: 21st Jul 2011, 06:01 pm
  2. Datum identifier missing the suction cup
    By tonika in forum AutoCAD General
    Last Post: 22nd Mar 2010, 11:51 pm
  3. Cross Section Datum
    By Hardney in forum Civil 3D & LDD
    Last Post: 28th Aug 2009, 02:56 pm
  4. Datum help for machine shop
    By volcom1121 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jun 2008, 08:39 pm
  5. Map transformation
    By Nazia in forum AutoCAD Beginners' Area
    Last Post: 22nd Jun 2006, 09:41 am
