Results 1 to 4 of 4
Thread: cad to xyz
    Forum Newbie
    AutoCAD 2013
    Jun 2012
    2
    Default cad to xyz
    hi
    i want to convert autocad drawing which indicates water depth data as text into txt format...x reference and y reference and the digital value indicated at the reference in xyz format...can anyone help me in exporting the dwg file...
    gmr
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    Please check the build-in DATAEXTRACTION command.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Newbie
    AutoCAD 2013
    Jun 2012
    2
    i did it sir but it extracted x and y positions not the text entered at xy reference....its a value created in a seperate layer called sounding i want to extract that value along with the x and y.ur help is needed
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    The said command will allow you to select which features to extract – for your case choose: Value, Pozition X and Pozition Y.
    Regards,
    Mircea
