If you've not done so already, open a new text file, and paste the script sequence in the empty text file. Save this text file with an ".SCR" file extension, for example "LoadMyMap2012workspace.SCR" (i.e., YourFileName), and note the location that you have saved this newly created script (i.e., YourFilePath)... "C:\Temp\" for example?
Then, within the application icon's Target, you will replace the YourFilePath with the location above, and YourFileName with the file name of your choosing. Building on the example here, it might look something like this:
Code:"C:\Program Files\Autodesk\AutoCAD Map 3D 2012\acad.exe" /b "C:\Temp\LoadMyMap2012Workspace.scr"
