+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Forum Newbie
    Using
    not applicable
    Join Date
    Jun 2012
    Posts
    1
    Default How to rotate an object in solidworks please?
    Hi,
    Can anyone tell me how to rotate the an image in solidworks?
    I have attached one image i need it to stay basically upside down rather than layed down like it is.
    Do i need to change it from the sketch or is there anything which allows my image to be rotated?
    Thank you
  2. #2
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,092
    Default
    I moved your thread to the SolidWorks forum.
  3. #3
    Senior Member bhamze's Avatar
    Using
    not applicable
    Join Date
    May 2010
    Location
    Florida
    Posts
    154
    Default
    Try the move/copy bodies command.
    Certified SolidWorks Expert -Advanced Surfacing, Mold Tool, Weldments, Drawing Tool and Sheet Metal Specialist
    http://www.solidworkslessons.info/
  4. #4
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,904
    Default
    Why do you need to rotate?
    Hold down mouse wheel and move mouse.
    If you are trying to change relative to coordinate system, why? It should be irrelevant. A part can be in any orientation in an assembly.
    More information on the true problem description is needed.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
Similar Threads
  1. Rotate Any Object/text?
    By pablo_aaron in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jul 2008, 05:38 am
  2. Rotate Object From Centerline
    By wahlwesle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Apr 2008, 07:20 pm
  3. Rotate object that is attached to another
    By 97catintenn in forum SketchUp
    Last Post: 25th Feb 2008, 03:30 am
  4. isolating an object to rotate on 3d axis
    By ethrim in forum AutoCAD Beginners' Area
    Last Post: 1st Nov 2005, 05:08 pm
  5. Rotate a 3D object
    By ChrisM in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2005, 09:03 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
