+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
  1. #1
    Forum Newbie
    Using
    MEP 2012
    Join Date
    May 2012
    Posts
    8
    Default MEP 2013 Devices Have a 0' 0" Elevation in Navis 2012
    Hi there, we recently updated our suite to 2013 (not recomended) we broke the company rule of waiting for the first update to be released before doing any upgrading, but we wanted to see if some of the new features would help with what we might be getting into. I know that 2013 has the new format that autocad updates every 4 years bla bla bla. All of the projects we are working use the old file format, so we save to the 2010 option. I have several lights that I created devices for in 2013, when this file is saved as a 2010, and brought into Navis or MEP 2012 all of the lights are inserted at the insertion point of the world coordinate system (under additional information in the properties box). Has anyone else had this problem? I have changed proxy graphics, blocked things, ex.... If you have found a way around it I would greatly appreciate it! Thank you to all of those who have sharred other information in this forum in the past!
  2. #2
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    How are you getting these files into Navisworks? Are you using NWCOUT to load the Navisworks Cache file into the program, or simply Appending the DWG file?
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  3. #3
    Forum Newbie
    Using
    MEP 2012
    Join Date
    May 2012
    Posts
    8
    Default
    The file is being appended into Navisworks, I will try a cache file to see what that does...
  4. #4
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    NWCOUT is always the method you want to technically use. It creates much less headaches and there's more info embedded for Navisworks to work with.
  5. #5
    Forum Newbie
    Using
    MEP 2012
    Join Date
    May 2012
    Posts
    8
    Default
    I would agree, however, we use each others files in AutoCAD as xreffs while we are drafting for obvious reasons, and not everyone has NavisWorks to check themselves...
  6. #6
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    Quote Originally Posted by rwjohnstone View Post
    That's all fine and dandy but NWCOUT has nothing to do with your current XREF situation. It doesn't interfere with the AutoCAD setup in any way, unless I am missing something.
  7. #7
    Forum Newbie
    Using
    MEP 2012
    Join Date
    May 2012
    Posts
    8
    Default
    Even when the light file is xreff into autoCAD 2012 as a dwg, the devices have no elevation to them. I need to be able to send a file or "files" out that can be brought into AutoCAD as an xreff and into Navisworks to show the elevation of the lights.
  8. #8
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    Ah, so you're having issues with the AutoCAD file itself, not necessarily the Navisworks export. Hmmm.... well I don't have 2013 at work yet so I can't help out. Seems a lot of people are having issues with the new file format though.
  9. #9
    Forum Newbie
    Using
    MEP 2012
    Join Date
    May 2012
    Posts
    8
    Default
    I would NOT install it yet, personally I would wait until 2014, the first two installs I did crashed about 20-30 times a day, now I get a ton of errors before the program starts, I hit ignore about 50 times and it works fine for the rest of the day???? Oh well. Thanks you for your time
  10. #10
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,483
    Default
    Well, Revit 2013 and Navisworks 2013 we have and those have been working flawlessly thus far. AutoCAD it seems has always had problems when they jump versions. Hell, even non-file format versions have been horrific. AutoCAD 2009 was the biggest upset and that was a last year version of the file format lol. *shrugs* I guess some things never change.
Similar Threads
  1. Replies: 3
    Last Post: 16th May 2012, 02:17 pm
  2. Tough Questions - "Z" Elevation Overrides
    By johnshar123xx in forum AutoCAD General
    Last Post: 30th Nov 2009, 09:51 pm
  3. I Cant Array in "Edit in Elevation"
    By Currahee in forum Architecture & ADT
    Last Post: 20th Sep 2009, 11:52 am
  4. Lost "Elevation" box in Properties Box
    By Tino in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Aug 2008, 01:36 pm
  5. Changing "Z" or Elevation of 3d Elements
    By Lora_D in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Feb 2008, 06:56 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
