Results 1 to 7 of 7
    Senior Member
    YZ's Computer Details
    Windows XP
    Intel Duo Core E6550 @ 2.33GHz
    1.98 GHz, 3.23GB RAM
    Intel G33/31 Express Chipset Family
    LG Flatron W2343T
    Surveying
    YZ's Discipline Details
    CAD Operator and Manager; Land Survey, Civil Design
    Surveying
    Topographic ground surveys for architects and engineers; Subdivisions in NSW; Civil Engineering Design.
    AutoCAD LT 2012
    Oct 2007
    Sydney
    256
    Default Button Macro to Utilise CHANGE command on all blocks and text
    Is there a way to use CHANGE command globally? It does precisely what I want, except that it does it one object at a time.
    I just stumbled on CHANGE command this week and I thought I'd found my Holy Grail.
    I have always wanted a macro that can change the rotation of all blocks to match the VIEWTWIST. But CHPROP only deals with Layer type changes.
    1. Is there a way to CHANGE all blocks at once? (In an automated macro) or
    2. Is it possible to get the macro to loop and input the new settings for as many blocks as are in the drawing?
    Senior Member
    Windows XP
    LG Flatron W2343T
    Surveying
    Surveying
    AutoCAD LT 2012
    Oct 2007
    Sydney
    256
    Does anybody even use the CHANGE command? I cannot see how it is helpful, unless you only want to change 1 object, in which case why not simply change it in the properties?
    I have not gotten any further on this. It is a difficult thing to search on account of the word being used frequently in posts unrelated to the command itself.
    Has anybody used a loop inside a macro? Or a script for that matter (though I'm very rusty at scripts, I'm ready to learn). I'll try the * operator at start of my macro to see if that loops. It's just that I'm nervous it will crash in this case.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    Re Change all blocks at once answer is yes but depends on your question there is numerous stuff you can do to blocks can you describe your request a bit more.
    Senior Member
    Windows XP
    LG Flatron W2343T
    Surveying
    Surveying
    AutoCAD LT 2012
    Oct 2007
    Sydney
    256
    On all our jobs we manually select all block references and set their scale and rotation according to the viewport scale and viewtwist.
    I am hoping to automate this with one button that reads the viewport properties and adjusts the blocks accordingly.
    Now that I write this "out loud" it seems like something that "annotative" blocks could also do. I am open to that option, just have never got them to work before.
    (Note LT, so I cannot use LISP solutions).
  5. #5
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    756
    dynamic blocks sound good for this, but i've never had much joy learning them, either. ignoring that.....
    sounds like you want a macro that does this:
    select all blocks
    specify scale
    specify rotation
    think this could be done, i'll try but think it's beyond my skills.
    i think to automatically specify same angle as viewtwist would need lisp.
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    One question why are you rescaling the blocks ? or is it just that they are diagramatic and true size is irrelevant .
  7. #7
    Senior Member
    Windows XP
    LG Flatron W2343T
    Surveying
    Surveying
    AutoCAD LT 2012
    Oct 2007
    Sydney
    256
    Quote Originally Posted by designerstuart View Post
    select all blocks
    specify scale
    specify rotation
    Yes that is essentially what I am hoping to automate. I would be satisfied with a macro that achieves the first step alone!
    I'm hoping to use DIESEL to setvar userr1 with the twist angle and then read it back. But I think it is a little too ambitious.
    One question why are you rescaling the blocks ? or is it just that they are diagramatic and true size is irrelevant.
    BIGAL, yes our blocks are diagramatic only. (Except in the case of trees, which our clients are now asking for them to be at the correct scale and so we manually update them after this step - but I digress). There is a function to set hatches parallel to viewport, that would be amazing to utilise that function into block definition. And perhaps, as I talk this out on the forum, annotatively scaled blocks really is the best way forward. I will try another one early next week, but I have to admit I'm nervous.
  1. SELECT in macro won't stay selected!!!! How to hide Macro in command line aswell?
    By jamesfear in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 31st Jul 2012, 02:23 am
  2. Change text inside blocks
    By maksolino in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Feb 2011, 04:29 pm
  3. Change Command Line Text Colour
    By civil_graham in forum AutoCAD General
    Last Post: 26th Feb 2010, 05:42 pm
  4. Change Text Rotation via Macro
    By SeaRR85 in forum AutoCAD General
    Last Post: 12th Nov 2008, 08:45 pm
  5. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
