+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Using
    AutoCAD 2012
    Join Date
    Jun 2012
    Posts
    8
    Unhappy AutoCAD tool palettes
    Anyway so here's the problem: I am struggling to edit the standard set of blocks that comes with AutoCAD such as receptacles junction boxes etc. I want to edit the standard blocks and then save my changes for future use. Right now the blocks come in at different sizes then I would like. I try to edit them in the block editor however the changes I make only apply to the drawing I am currently working on. The changes do not apply across the board on all drawings in all files. Please help me, any and all help would be hugely appreciated!
    Thank you!
  2. #2
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,588
    Default
    Are you trying to edit the AEC Objects from AutoCAD MEP? Or are you editing the standard 2D blocks from vanilla AutoCAD? If you are trying to edit the AutoCAD MEP ones, there's a process you have to follow.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  3. #3
    Forum Newbie
    Using
    AutoCAD 2012
    Join Date
    Jun 2012
    Posts
    8
    Default
    Yes, precisely. I am trying to edit the AEC Objects from AutoCAD MEP. If you could help me through the process or point me in the right direction i would really appreciate that.
Similar Threads
  1. Replies: 0
    Last Post: 18th Jul 2011, 10:40 pm
  2. Import tool palettes from ADT to AutoCAD
    By cggentry in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Aug 2010, 07:40 am
  3. Tool Palettes
    By funky fedaykin in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Nov 2009, 01:02 am
  4. How custom tool button images are created for tool palettes
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2007, 04:13 am
  5. Add commands to tool palettes from the CUI dialog box in AutoCAD 2007
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 13th Sep 2006, 12:40 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
