+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Junior Member
    Computer Details
    Mechanical's Computer Details
    Operating System:
    Windows 7
    Discipline
    Mechanical
    Mechanical's Discipline Details
    Occupation
    Drafter & Design Engineer
    Discipline
    Mechanical
    Details
    Water Infrastructure Designer: Designing various things like P&IDs, Water Treatment Plants, Dosing Plants, Dams, Pumping Stations, Waste Water Treatment Plants, etc.
    Using
    AutoCAD LT 2011
    Join Date
    Mar 2012
    Posts
    13
    Default Viewport Rotation
    Can someone smart with Autocad tell me why this happens?
    Okay, in modelspace I have a drawing that is aligned perfectly, but when I create a new viewport in a layout the drawing that was created in modelspace seems slightly rotated in the layout view?
    Can someone please offer any suggestions.
  2. #2
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,135
    Default
    You say that in Modelspace it is aligned perfectly, which begs the question,
    to what?
    If the UCS in your modelspace is something other than WCS, you would experience a different perspective (either slightly or wildly) in your
    newly created viewport.
    Another possible scenario might be that your Modelspace view is set to PERSPECTIVE view as opposed to PARALLEL view.
    Try entering PERSPECTIVE at the commandline and making sure that it is set to ZERO.
    Are you at liberty to post the drawing, or a very stripped down version of it, which is all it would take to debug the problem?
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,791
    Default
    A bit more if you have set your modelspace to a diiferent UCS then just UCS S name then in viewport UCS R Name plan
  4. #4
    Senior Member khoshravan's Avatar
    Computer Details
    khoshravan's Computer Details
    Operating System:
    Windows 7
    Computer:
    Sony Vaio
    Using
    AutoCAD 2010
    Join Date
    Feb 2009
    Location
    Tabriz
    Posts
    422
    Default
    Quote Originally Posted by Dadgad View Post
    I thought perspective command is only deal with 3D objects.
    How is it used in 2D drawings.
    I checked ACAD help but didn't get the point which I quote here.
    Perspective projections require a distance between a theoretical camera and a target point. Small distances produce severe perspective effects; large distances produce milder effects.
    A perspective view remains in effect until the perspective effect is turned off or until a new view is defined in its place.
Similar Threads
  1. Viewport Rotation Problem
    By Colonel_CAD in forum AutoCAD Beginners' Area
    Last Post: 31st Jan 2012, 06:36 pm
  2. viewport rotation properties
    By jcdewick in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2012, 03:13 pm
  3. Rotation of drawings in vieport without model rotation
    By intern2011 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Sep 2011, 04:02 pm
  4. Replies: 4
    Last Post: 25th Feb 2009, 05:25 pm
  5. Viewport rotation
    By shellb in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2008, 02:39 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
