+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
  1. #1
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    Jun 2012
    Posts
    2
    Default Getting dimensions from a model
    I am new to AutoCAD and have been sent a 3D architectural model. I need to find the dimensions of some beams. The measure tool seems only to measure from point to point, and I need to measure from one side (or edge) of the beam to the other. The beams are not along the axes and the ends are not at right angles so there are no points that correspond to the height and width.
    In Sketchup, I can easily measure from one line to any parallel line. How can I do this in AutoCAD?
    Thanks,
    Julian
  2. #2
    Forum Deity MSasu's Avatar
    Discipline
    Construction
    MSasu's Discipline Details
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    2,986
    Default
    I’m not aware of such built-in feature in AutoCAD to measure from edge to edge on 3D solids.
    May try to measure from an arbitrary point from first item to a perpendicular to the second one - check Osnap mode for this. To overide temporary current setting, just press simultaneously <Shift> and right-click on mouse.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  3. #3
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    Midpoint to perpendicular?
  4. #4
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    Jun 2012
    Posts
    2
    Default
    That's just what I needed. Thanks very much Mircea.
    Julian
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    If the arbitrary point is not selected using one of the Osnap overrides then how do you know what you're picking as that first point?
  6. #6
    Discipline
    Construction
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    2,986
    Default
    You are right, I should have given a much detailed explanation on this. I have implied that an arbitrary point selection requires usage of Nearest mode, but other may not think the same. Sorry for confusion and thank you for correction.
    Regards,
    Mircea
  7. #7
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    It is not a matter of me correcting you. I just want to make sure, as I think you do too, that the OP is picking somewhere on the correct beam or some portion of it otherwise the distance he gets may be incorrect.
  8. #8
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    Welcome to the forum.
    In 2012 and 2013 you have available 3D Object snaps.
    Volume and repetition do not validate opinions forged in the absence of thought.
  9. #9
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,131
    Default
    Quote Originally Posted by ReMark View Post
    It is a matter of me correcting you. I just want to make sure, as I think you do too, that the OP is picking somewhere on the correct beam or some portion of it otherwise the distance he gets may be incorrect.
    I'm guessing you meant to say it is NOT a matter of........
  10. #10
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    You are correct. I did forget the word "not". Jeez, I can't type today.
Similar Threads
  1. Modify my model in CAD/Change Dimensions
    By User2012 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Jun 2012, 03:36 pm
  2. I have a 3ds model i want to annotate with dimensions
    By djwang in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2012, 07:39 pm
  3. Drive feature dimensions with sketch dimensions?
    By Hickoz_bro in forum SolidWorks
    Last Post: 15th May 2011, 01:41 am
  4. Dimensions for presentation of a 3D model?
    By cvriv.charles in forum Autodesk Inventor
    Last Post: 17th Mar 2010, 05:42 pm
  5. Location of anchor points on dimensions in Model Space
    By Crazy J in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2010, 05:41 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
