Results 1 to 4 of 4
    Forum Newbie
    Architecture 2011
    Jun 2012
    2
    Default Scaling Text field size without moving its position
    Hi
    I am trying to enlarge the text from an exported cad drawing from Dialux (lighting calculation software)...it has exported a field of values over a large area but the text is really small and illegible when its plotted as an A1 pdf
    Is there anyway to blow all the text values up at once without moving them from their positions with relation to the boundaries of the roads and buildings?
    Here is a screenshot of the view with CAD...this is a small area of the entire scheme and those little black smudges are the numbers i need to scale
    I guess in a 3D program this would be equivalent to having the pivot point located in the centre of each set of numbers so you could scale them using the centre of each number as its scale point but I am stumped by how to do this in Autocad Architecture 2011...please send help urgently!
    Many thanks
    Senior Member Blackfish's Avatar
    AutoCAD LT 2012
    Apr 2012
    182
    Welcome to the forum
    Select all text and change height in Properties Dialog Box (CTRL+1)
    LT is still AutoCAD
    Forum Newbie
    Architecture 2011
    Jun 2012
    2
    Ah ha thanks Blackfish....Dialux was importing each numbered field as a block but if i blow the blocks up then i can change the text height.
    Thanks very much, I knew it was something obvious id missed. Awesome
    AutoCAD LT 2012
    Apr 2012
    182
    Quote Originally Posted by Coobacca View Post
    You're welcome.
    If each text is a separate block you can change scale (X, Y & Z) of all block in the same Properties Dialog Box, so you don't have to explode blocks.
    LT is still AutoCAD
  1. Replies: 5
    Last Post: 20th Dec 2011, 01:33 pm
  2. Scaling and Text Size
    By Kemphas in forum AutoCAD Beginners' Area
    Last Post: 30th Aug 2010, 06:57 pm
  3. Scaling multiple objects and keeping orginal position.
    By MichaelP in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Feb 2010, 04:25 am
  4. help with scaling/moving blocks
    By mohamed reda in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Jan 2010, 02:57 pm
