+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
  1. #11
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,178
    Default
    Do you know where the AUTOSAVE files are stored?
    If not go to OPTIONS, and on the FILE tab, as shown in post #5 you can check to see where they are stored.
    Go to the AUTOSAVE file, once you know where it is, and check for a .BAK file with the same drawing name as the one you are hoping to restore.
    Should you find it, right click on it and RENAME it. What you want to do is change the file extension to .dwg
    , then open it and see if your 3D modeling work is still in that file.
    Good luck, hope you get lucky.
    Volume and repetition do not validate opinions forged in the absence of thought.
  2. #12
    Full Member
    Using
    AutoCAD not applicable
    Join Date
    Apr 2010
    Posts
    26
    Default
    went to view, selected set current, ok. Still get the tricolor corr
  3. #13
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    Are you in PERSPECTIVE or PARALLEL view?
    Enter ORBIT at the commandline, then right click, and if you find that PERSPECTIVE is checked, check PARALLEL instead, then ESC.
  4. #14
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    Wait a minute, this is a drawing of your bathroom? I'm guessing there is no reason you can't post it? Security clearance issues?
    You're bathroom isn't in the west wing of the white house?
    I will happily check it right out for you, and we can put this issue to bed.
  5. #15
    Full Member
    Using
    Join Date
    Apr 2010
    Posts
    26
    Default
    Thanks for your help. I went to options and found the autosave but it says that it is in a temp file which I can not find. I've been saving the drawing on the desktop and it is labeled bathroom.bak. I open it through autocad.autosave.JPG
  6. #16
    Full Member
    Using
    Join Date
    Apr 2010
    Posts
    26
    Default
    Sorry I had to log back in and did not see your white house post. made me LOL. I'll see if I can figure out how to upload the dwg
  7. #17
    Full Member
    Using
    Join Date
    Apr 2010
    Posts
    26
    Default
    OK, how do I upload/post an Auto CAD dwg?
  8. #18
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    REPLY > GO ADVANCED > MANAGE ATTACHMENTS > BROWSE > UPLOAD > CLOSE THIS WINDOW > SUBMIT REPLY
  9. #19
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    Personally I like to specify another less transient location for my AUTOSAVE folder, although that is the default.
  10. #20
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    For the time being forget about autosave.
    Change the file extension of the .BAK file on your desktop, as previously described to .dwg, then open it.
Similar Threads
  1. auto cad 2010 help files
    By prabhathjp in forum AutoCAD General
    Last Post: 23rd Mar 2012, 08:43 am
  2. Auto Cad P&ID 2010
    By Big G in forum P&ID
    Last Post: 30th Sep 2011, 01:59 pm
  3. HELP! lost layout tabs. I want them back. AC 2010
    By CalypsoArt in forum AutoCAD General
    Last Post: 16th Dec 2010, 02:03 pm
  4. Auto Architecture 2010
    By Marc5 in forum Architecture & ADT
    Last Post: 27th Aug 2010, 12:02 pm
  5. ACAD 2010 how to back up license?
    By veinsilk in forum Software & Licensing
    Last Post: 29th Oct 2009, 05:41 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
