scoo9 Posted June 24, 2012 Share Posted June 24, 2012 hello all,, hope all is well. I've got a issue with working with images. I draw furniture full scale and sometimes it necessary to hard draw and scan the drawing and then attached the image in autocad and trace over the image in AutoCAD 2013. everything is fine until I attach the image, then it freezes with every move that I try to make. The images are around 700 kbs in size. Is there anything I can do or change some kind of setting?? btw. version 2004 doesn't have this problem. I'm running windows 7 pro Dell XPS M1710 4 gb memory any help will be greatly appreciated Thanks Scoot Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 25, 2012 Share Posted June 25, 2012 What graphics card and driver? 32-bit or 64-bit? That was an expensive and powerful gaming computer when it came out in '05 or '06, but AutoCAD 2013 might not like it though. Quote Link to comment Share on other sites More sharing options...
scoo9 Posted June 25, 2012 Author Share Posted June 25, 2012 Hey,, thanks for the reply SLW210. I'm at work at the moment and will let you know the exact type of graphics card I have but I do know it's a 32 bit. Yes, I'm at work right now using AutoCAD 2004 LT and it doesn't have a problem working with the images. I really like the new AutoCAD format and the new abilities, hate to go back to the older versions tho.. but I will if necessary, of course. and FYI.. if this matters? when you look in the computer properties and review the base scores the graphic card is normally the lowest and mine is 4.2. I've seen others post over 5.0 using this same machine. thanks Scoot Quote Link to comment Share on other sites More sharing options...
tuomojar Posted February 25 Share Posted February 25 I had this same issue (2024). After a while it just disappeared and now works normally .. Quote Link to comment Share on other sites More sharing options...
