Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Full Member
    AutoCAD 2010
    May 2009
    Dallas, Texas
    38
    Default Title block and paper in paper space
    Hello,
    I have an old drawing where I am inserting layout from the template. The problem is that the template is off from the white sheet of paper. My templates are .dwt files and usually work fine.
    regards,
    Krystyna
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    You might have to adjust the template to fit the paper size you have selected unless you use a different paper size.
    What size paper did you select?
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    2 suggestions, move the title block lower left to 0,0 and like Remark check your paper size.
    If its the black you want choose printer set correct paper size window etc and scale then "Apply to layout" then "Cancel" black will remain with no print, you can then got to next layout use "page setup name" "<previous plot>" apply cancel and so on.
    Full Member
    AutoCAD 2010
    May 2009
    Dallas, Texas
    38
    107 GAB_ A0.jpgThank you guys, but it did not solve my problem: I have letter size paper and the title block made for letter size. When I insert the block it comes off.
    Krystyna
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Post a copy of the drawing you are attempting to insert. Tell us the paper size you are using too.
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Looks like your title block is way off in scale is it at 1:1 mm A1 =841x594 imp 24x36 image looks like a A4 of a A1 ie 8 times smaller
  7. #7
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    Please check the value of INSBASE system variable in the said template.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Are you going to post a copy of the drawing (title block and border) or not? Help us to help you by doing so if there is still a problem. If you have solved the problem please say so and we'll put this topic to rest. Thank you.
  9. #9
    Full Member
    AutoCAD 2010
    May 2009
    Dallas, Texas
    38
    I already posted a copy of the drawing with the attributes shifted inside the title block. If you do not know the remedy for that problem, I will live with it.
    Thanks for all your help.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    I'll try to be more clear the next time. Attach a copy of the actual DWG file to your next post.
    Did you read posts #6 and #7? Did you check to see if either applied to your problem?
  1. 3 Title Blocks in Paper Space
    By Bobzy20 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jan 2012, 09:26 pm
  2. Visibility of dynamic block in paper space
    By farsfo in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2011, 09:05 pm
  3. Referencing a title block from model space into a new tab of paper space?
    By AJC4 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jul 2011, 12:09 pm
  4. Title Block do not fit to the Layout Paper space
    By Daniel Bartolo in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jul 2011, 04:14 am
  5. title block inserted into paper space is huge
    By corinne in forum AutoCAD Beginners' Area
    Last Post: 25th Aug 2008, 11:11 pm
