Results 1 to 5 of 5
    Junior Member
    AutoCAD 2012
    Jun 2012
    15
    Default How do I change text edit to start at the end of a string of text?
    What I want to do is have text edit for single line text to start at the end of a string of text instead of high lighting the entire text. Is it possible to do this?
    Thanks
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    As far as I know, that's not possible. When I edit text, it seems to highlight exactly what I don't want highlighted. I always assumed it was Murphy's Law in action.
    breaking AutoCAD on a regular basis since 1991
    Junior Member
    AutoCAD 2012
    Jun 2012
    15
    That's exactly what I thought. Thanks
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,968
    If all the text is highlighted, try pressing the Right Arrow Key, then Space, then start typing.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    Hit CTRL+End, space, that way you will be ready no matter if it is mtext or single line text.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Globally edit text string with constant number
    By Dakine in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2012, 06:41 pm
  2. Text Color Change Makes Text Move??
    By geocad in forum AutoCAD General
    Last Post: 29th Dec 2011, 09:50 pm
  3. Change multiple Dimensions measured text into normal text?
    By apsonwane in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2011, 09:31 am
  4. Only text moves in dimension text edit
    By cduke5 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Apr 2011, 07:22 pm
  5. need lisp routine for global text string change
    By TFerg in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2006, 03:46 pm
Tags for this Thread
