How do I draw a line that STARTS at a perpendicular angle to another line
Start Line command, type PER, enter, pick line, move cursor, pick again.
This is for starting at an endpoint and perpendicular but this will work for you also.
Draw a line perpendicular to the endpoint of a line.
1. OTRACKING on,OSNAP endp and perp set, POLAR on, start line command,
acquire end point, move 90 degrees in direction you want, type the
value or pick, pick the point you first acquired.
2. Rotate the UCS with the OBject option, and draw away. I have this
automated with UO as my quick keys (UCS, OBject), and to go back I use
UW (UCS, World).
3. With POLAR set to Relative to last point, start the line command,
use an osnap, pick the line, move 90 degrees in the direction you
want to draw and enter
the value or pick.
4. Rotate the crosshairs with snap, rotate, pick two points on the
line, ... This is also easily automated with a lisp so you can pick
the line and have the crosshairs rotate.
I am sure there are others.
Edit: Removed.... 100% similar to rkent idea (see first line of his post)
Damn.. this is second time last week when it happens to me... I should start reading other`s posts :(
Edited by Stefan BMR
