Deaneric Posted June 28, 2012 Share Posted June 28, 2012 I have attached an image of the chair i'm modelling, I need to create the back and seat but can't find a way of modelling the curve feature. I can create the oval shape and extrude to 3d, fillet the edges etc but can't curve it. Any advice would be much appreciated I'm new to 3D Modelling Thanks Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 28, 2012 Share Posted June 28, 2012 You can extrude that shape more than his total height, draw its projection on back plane, extrude that to front and retain the common part (command INTERSECT). Next you may fillet the edges. Quote Link to comment Share on other sites More sharing options...
Deaneric Posted June 28, 2012 Author Share Posted June 28, 2012 Thanks MSasu, Can you explain what "draw its projection on back plane" means? bear in mind i'm really new to 3d cad Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 28, 2012 Share Posted June 28, 2012 I created a picture for you - the back projection is the red shape, while the result of intersection command is in blue: Hope that is clearly this time. Quote Link to comment Share on other sites More sharing options...
Deaneric Posted June 28, 2012 Author Share Posted June 28, 2012 :DBrilliant thanks, this has been bugging me for days!! Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 28, 2012 Share Posted June 28, 2012 You're entirely welcome! Quote Link to comment Share on other sites More sharing options...
Deaneric Posted June 28, 2012 Author Share Posted June 28, 2012 Sorry to be a pain, but i can't seem to create back projection as a solid, i draw the arc and lines and then extrude but it only extrudes as a shell?, sorry if this is really basic. Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 28, 2012 Share Posted June 28, 2012 You should create a closed polyline from those simple entities - align the UCS on said plan and check the PEDIT command. Quote Link to comment Share on other sites More sharing options...
Deaneric Posted June 28, 2012 Author Share Posted June 28, 2012 Thanks again Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 28, 2012 Share Posted June 28, 2012 My pleasure! Did you managed to create the desired shape? Quote Link to comment Share on other sites More sharing options...
Deaneric Posted June 29, 2012 Author Share Posted June 29, 2012 Perfectly, thank-you Quote Link to comment Share on other sites More sharing options...
