Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Default Dxf to file location
    Trying to get this lisp to save a dxf to a specific folder ex. C:\My Documents\DXF\. I tryed putting that in the code but I'm not writing it right or something. Could someone point me in the right direction.
    Code:
    (defun c:dxf ()
    (vl-load-com)
    (vlax-for LAYOUT (vla-get-layouts(vla-get-activedocument(vlax-get-acad-object)))
    (vl-catch-all-apply 'vla-delete (list LAYOUT))
    (command "CHANGE" "ALL" "" "P" "LA" "0" "")
    (command "-PURGE" "ALL" "" "N")
    (nowdxf)
    (defun nowdxf ()
     (command "saveas" "dxf" "")
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    I'd look into the DXFOUT command in lieu of saveas
    Also you will need \\ or use / for directory locations in lieu of the single \
    -David
    R12 (Dos) - A2K
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Tryed this. Its still not working. By usings just the saveas or dxfout, it works but I want to force it to this folder with out have to select it.
    Code:
    (defun c:dxf ()
    (vl-load-com)
    (setvar "CLAYER" "0")
    (command "change" "all" "" "p" "la" "0" "")
    (command "-purge" "all" "" "n")
    (nowdxf)
    (defun nowdxf (/ dxfname)
     (setq dxfname (getstring "n\DXF Name:  "))
     (command "_SAVEAS"  "DXF" "" (strcat "C:\\Users\\My Documents\\DXF\\" DXFNAME))
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,948
    If you're trying to avoid the SaveAs dialog, then consider this example:
    Code:
    (defun c:FOO ( / fileName)
      (vl-load-com)
      (if (setq fileName (getstring T "\nEnter a file name: "))
        (vla-saveas
          (vla-get-activedocument (vlax-get-acad-object))
          (strcat "C:\\Users\\My Documents\\DXF\\" fileName ".dxf")
          ac2010_dxf)
    "Potential has a shelf life." - Margaret Atwood
  5. #5
    Civil 3D 2011
    Nov 2009
    3,948
    Oh - Almost forgot... For reference: ActiveX SaveAs Method
  6. #6
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Thanks. It works perfect
  7. #7
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by bradb View Post
    Happy to help.
  8. #8
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    How different would this code look if dxfout were used instead of saveas. Just curious
  9. #9
    Civil 3D 2011
    Nov 2009
    3,948
    Pseudo code:
    Code:
    (defun c:FOO  ()
      (vl-load-com)
      (vlax-for oLayout  (vla-get-layouts
        (vl-catch-all-apply 'vla-delete (list oLayout)))
      (setvar 'clayer "0")
      (command "._change" "all" "" "properties" "layer" "0" "")
      (command "._-purge" "all" "" "no")
      (command "._dxfout"
               (vl-string-subst
                 ".dxf"
                 ".dwg"
                 (strcat (getvar 'dwgprefix) (getvar 'dwgname)))
               16)
      (princ))
  10. #10
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Cool. Still trying to learn this visiual lisp. Thanks
  1. .ctb File Location
    By LSDS in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jun 2012, 01:29 pm
  2. File Location on IDW
    By pgcust in forum Autodesk Inventor
    Last Post: 15th Aug 2008, 04:36 pm
  3. ac$ file location?
    By NEWUSER in forum AutoCAD Drawing Management & Output
    Last Post: 24th Aug 2006, 06:42 pm
  4. CTB file location
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2005, 03:55 pm
  5. BAK File location
    By geoffc in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jun 2005, 06:43 pm
