Results 1 to 7 of 7
    Forum Newbie
    Architecture 2011
    Jun 2012
    2
    Default Combining multiple layers in an existing map to one layer
    I am trying to combine the layers on a warehouse map into one layer. Is there an easy way to do this? Right now the layers are setup based on the types of architecture and my ultimate goal is to make layers based on the departments that work in each section.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,953
    Welcome to CADTutor!
    Consider the LAYMRG Command.
    "Potential has a shelf life." - Margaret Atwood
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,137
    +1 Absolutely the way to go.
    Forum Newbie
    Architecture 2011
    Jun 2012
    2
    I get the error message "Cannot merge current layer" for a few of the layers that I am trying to merge into this. In the properties I don't see anything different with the objects; also in the layer properties I don't see anything different compared to the other layers. The file size seems to be a bit too large (16mb) otherwise I would attach it here.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Grab all the objects, pick a layer, done.
    If you have 100 layers and 20 go on one layer, and 20 on another, etc, then freeze them all, thaw the 20 you need, then see above.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  6. #6
    Senior Member
    Doove's Computer Details
    7
    HP Elitebook
    Intel i7 M620 2.67GHz
    8GB
    NVidia Quadro FX880M (512MB)
    Inventor 2011
    Oct 2008
    South Wales
    135
    Layer Translator will do it too. (LAYTRANS)
    ... if I'm not back in twenty minutes... just wait longer...
  7. #7
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,239
    Quote Originally Posted by bigern87 View Post
    Change your current layer to one that is not involved in the merging.
    Rob
  1. Combining Files or layers
    By Sparkyxxx in forum AutoCAD Beginners' Area
    Last Post: 24th Oct 2011, 03:07 pm
  2. Multiple Layers moved to a single layer
    By lancedennis in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Jul 2011, 02:46 pm
  3. question about combining layers and commands
    By canuck7783 in forum AutoCAD Beginners' Area
    Last Post: 5th Sep 2008, 11:14 am
  4. overwriting existing layers with imported layers
    By Dro in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2008, 12:47 pm
  5. Spliting a layer into multiple layers
    By luke.d in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2008, 12:33 pm
