+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    Box one was created using lines. It was then given a height using the EXTRUDE command. The result is a four sided box (open inside) comprised entirely of surfaces.
    Box two was created using a continuous polyline. It was given a height using the EXTRUDE command. The result is a solid through and through. Slicing the box in half would confirm the fact.
  2. #12
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    Box three was constructed from four lines but instead of using the EXTRUDE command the PRESSPULL command was used. The result is a solid. This can be confirmed either via the Properties palette or as I have shown here (box four) slicing the box in half.
  3. #13
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,134
    Default
    Quote Originally Posted by ReMark View Post
    I would argue that the CONVTOSOLID command is not obsolete at all. Just because the command failed doesn't mean it is obsolete. The failure, as it were, could be attributed to the geometry that is being used or the fact that the user did not understand or follow the command prompts.
    Has SURFSCULPT stolen some of CONVTOSOLID's thunder?
    An honest question, having not used either one.
    Volume and repetition do not validate opinions forged in the absence of thought.
  4. #14
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,134
    Default
    Quote Originally Posted by Tiger View Post
    in learning the CONVTOSOLID command you probably learned other things that will still be useful down the line.
    yeah, like PRESSPULL!
  5. #15
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    Note that meshes can be converted to solids using CONVTOSOLID.
    I would agree that SURFSCULPT would probably be of more use to the OP as long as he was working with the proper geometry.
  6. #16
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    An example of a mesh cube (number 5) converted to a solid (number 6) using the CONVTOSOLID command.
  7. #17
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    A six-sided box constructed entirely of surfaces.
    The same box (number eight) after its conversion to a solid using SURFSCULPT. Number nine is the result of using the SLICE command to cut the box in half. Solid through and through.
  8. #18
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,134
    Default
    Attachment 35650
    >Attachment 35651
    I'm guessing you took my advice about hooking up the IV ITALIAN ROAST drip yesterday, that or you slept a lot better last night, firing on all cylinders today!
  9. #19
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,118
    Default
    Seven out of eight cylinders are cranking along. I'll be working on the eighth in just a couple of minutes. Coffee break time!
Similar Threads
  1. 2d lines/polylines to 3d polylines
    By iain9876 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Dec 2011, 11:47 am
  2. Multiple lines to polylines. Need help please
    By Dec in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th May 2010, 04:00 pm
  3. remove double lines from drawing(lines,polylines,text)
    By cadamrao in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2010, 02:35 pm
  4. extruding multiple polylines
    By izz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Nov 2008, 12:17 pm
  5. multiple polylines
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2007, 01:06 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
