Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2007
    Jun 2012
    6
    Default how to start a sketch at coordinate z at a height?
    like in the attachment,i can creat a box from XY plane(which implies Z=0),and i can pull(extrude) to a height ,to say 100,a solid created.then from this plane i want to creat a header at a different XY region.How i can freely draw a sketch (locked) in this plane like i draw in Z=0,XY plane?I have tried UCS(creat a new ucs at the top of the former solid) in 3d,but when i projected to top view to draw the box ,it is still drawn in Z=0 plane,and pull up or down from that plane ,but what i want to creat is an object from height maybe 60 to 100,or even 60 to 70,it do not touch Z=0 at all.This problem confused me for severals days!
    Forum Newbie
    AutoCAD 2007
    Jun 2012
    6
    by the way how to use leader and text to note the solid in 3d,shame to make the note in drawing in other soft.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,000
    Not sure that understand, you were looking to draw in a plan, other than current 0? You should move temporary the UCS (translate on Z) to the desired elevation, draw what you need and revert to previous UCS or WCS when the sketch is done. Only after this final step you should validate the elevation of said sketch.
    Please don’t forget that while the UCS is moved, the listed coordinates are expressed in current UCS; thus when you translate it on Z, the draw plan will be always 0.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,068
    Look into the OSNAPZ system variable or maybe ELEVATION?
  5. #5
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Use dynamic input, and use POLYLINE command or POLYGON or CIRCLE or RECTANGLE.
    When specifying your first point use direct data entry like 0,0,200 , and in that way as all of these commands
    draw on a plane which is parallel to the X, Y plane in your UCS, you will wind up drawing at the elevation entered in your
    first point input.
    Command: 11
    PLINE
    Specify start point: 200,200,500
    Current line-width is 0.0000
    Specify next point or [Arc/Halfwidth/Length/Undo/Width]: <Ortho on>
    Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
    Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: <Osnap on>
    '_+dsettings >>Tab Index <0>:2
    Resuming PLINE command.
    Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: '_+dsettings
    >>Tab Index <0>:2
    Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: c
    For better viewing and enhanced control, do your PRESSPULL or other modeling commands from an isometric perspective, in this way you can enter direction and it
    won"t default to zero elevation on the Z axis.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,068
    If one were drawing multiple objects at an elevation other than that of 0.00 what would be the quicker way of doing it?
  7. #7
    AutoCAD 2012
    Nov 2011
    3,134
    I would just draw it or them on the current layer, then LEVITATE it maybe my Levity is misguided,
    perhaps ELEVATE would be better.
  8. #8
    Full Member
    AutoCAD 2011
    Mar 2003
    Lousiania
    35
    you could go to tools/new ucs/ then object and pick top plane.
  9. #9
    Full Member
    AutoCAD 2010
    Aug 2009
    Ontario, Canada
    56
    You can set your UCS origin to whatever height you want using the 3 coordinate values, or by clicking on an endpoint of an existing 3D model.
    Command: UCS
    Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: Origin
    Specify new origin point <0,0,0>:0,0,60
    Now whenever you draw an object, it will be at the height you set your UCS to.
  10. #10
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,372
    Quote Originally Posted by vib View Post
    You need to manipulate the ucs to do this. In your example the ucsicon has x,y plane shown as if on a top view with Z pointing up. Use the UCS command and rotate the UCW so the Z is pointing toward you from the left plane. Try using UCS, Object, select the object for A. It takes some practice, the newest releases make manipulating the UCSicon much easier, not that that helps you any.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Interpolate height with showing distance and height on cursor
    By cadplayer in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2012, 09:47 am
  2. 2D map - height of terrain to 3D
    By wishgranter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2012, 10:17 pm
  3. adjust dim text height in sketch dimensions?
    By rkent in forum Autodesk Inventor
    Last Post: 22nd Nov 2010, 02:15 am
  4. Inventor 08 sketch coordinate system
    By DBDBW in forum Autodesk Inventor
    Last Post: 15th Jun 2010, 07:09 pm
  5. inventor sketch to autocad sketch posible?
    By matulja87 in forum Autodesk Inventor
    Last Post: 11th Aug 2009, 03:11 pm
