Results 1 to 5 of 5
    Full Member
    3ds Max 2013
    Jun 2012
    27
    Default "Save as" problem?
    When I finished adjusting my object yesterday, I had ran a stl check and had no errors. I downloaded that as a "save as" to my documents. Today I opened the file to find the file is not the same file as I downloaded and has many errors, in fact, I wonder if it is identical to the file I started with yesterday morning? What did I do wrong? How do I make certain that the file I want to save is the one that I want to save? Thanks.
    Full Member
    3ds Max 2013
    Jun 2012
    27
    I'm still not certain what happened to that file, but yesterday I made sure my saved file was the one I wanted, not something else. I lost Friday's work due to that and didn't want that to happen again.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,486
    What do you mean you "downloaded" it?
    If the file had no errors when you saved it then it should have no errors when you open it. Are you sure you're opening the correct file? In your Windows Explorer, check the date and time of the file and make sure it's the correct date and time of the file you last saved.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,176
    You do understand that SAVEAS requires you to give your file a new name?
    It sounds to me like you are opening the original file, not the SAVEAS version too, per Cad64's comment, confusion.
    Check in your DOCUMENTS folder, if that is your default location for the SAVEAS command.
    I would strongly suspect that you have merely misplaced the SAVEAS version of your file.
    Good luck, I hope you find it.
  5. #5
    Full Member
    3ds Max 2013
    Jun 2012
    27
    Thanks for the advice. Not certain what happened and I been working obsessively since then to complete this project. I'll look over my files when finished.
  1. Replies: 0
    Last Post: 15th Nov 2010, 08:30 am
  2. Replies: 6
    Last Post: 26th Aug 2010, 08:02 pm
  3. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 17th Feb 2010, 06:45 am
  4. AcadMap3D 2010_freezes on "open" or "save" ...
    By Jest in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 26th Aug 2009, 08:27 am
  5. "User defined attribute list" won't save settings
    By M_Simons in forum Electrical
    Last Post: 17th Aug 2009, 04:15 pm
