Results 1 to 4 of 4
    Forum Newbie
    AutoCAD LT 2011
    Jul 2012
    1
    Default annotative text issue
    Hi Guys, new to AutoCAD and also this forum. I have text that I want to be able to plot at vaious different scales. I added annotative text in model space and scaled at 1:20, 1:50, 1:100 and 1:125. The scale is set at 1:125 in model space. If I set my viewport scale at anything other that 1:125 I either get mutiple versions of the text all over the place and / or very small versions of teh text offet from where I placed them in model space. What the devil am I doing wrong ?
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    From the sounds of it you are doing it right. The multiple versions of different sizes appearing in model space can be turned off (I can't member the command currently though). The text appearing offset/in slightly different positions when in different viewports at different scales is the big problem I have with annotative scaling and why I don't use it personally.
    Full Member dirkvandonkelaar's Avatar
    dirkvandonkelaar's Computer Details
    Windows 10 x64
    ATEC Performance One P180 Mini - Black
    Asus M4A78-EM
    AMD Phenom II X4 945, 3,0GHz
    2x Kingston ValueRAM KVR800D2N5K2, 2GB
    ASUS Radeon HD 5700, 512 MB
    Samsung Spinpoint F3 HD103SJ, 1TB, RAID1
    Synology DS415+, 4x3TB RAID 5
    Samsung SyncMaster 2232BW
    Multi-disciplinary
    dirkvandonkelaar's Discipline Details
    Construction
    Multi-disciplinary
    Architectural, Engineering
    AutoCAD 2017
    Apr 2011
    Overberg, The Netherlands
    71
    Quote Originally Posted by Dink87522 View Post
    the command is "annoallvisible" you need to set this to 0.
    When you had this set to 1, try to set it to 0, maybe your problem is solved.
    "The only job where you start at the top, is digging a hole."
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by dirkvandonkelaar View Post
    Welcome to the forum.
    dirk nailed it.
    You might want to read the yellow highlighted text in the attached image though, for future reference.
  1. Annotative Text How To
    By resullins in forum AutoCAD General
    Last Post: 4th Nov 2011, 03:06 pm
  2. Help with annotative text
    By davidjb82 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Sep 2011, 01:10 pm
  3. Annotative block issue
    By markv in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Jan 2011, 02:45 am
  4. Annotative Text
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2010, 02:23 am
  5. Need help with Annotative text
    By LAD152 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2010, 06:45 pm
