Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Junior Member
    AutoCAD 2010
    Jul 2012
    12
    Working code:
    Code:
    ;;;  Program to read the output data from the Corpson6 coordinate conversion
    ;;;  By Ron Auble, 01/19/07, Auble Consulting.    Last update 01/19/07
    ;;;  Passed: Nothing, prompted to select a data file
    ;;;  Return: List of lines from data file in the form of '("Label" X-value Y-value)
    (defun ReadUTM ( / FName LINE xFN Comma LblStr RemStr Xord Yord DatITM DatLST)
      (setq FName (getfiled "Select Data File" (getvar "DWGPREFIX") "txt" 0))
      (if FName
        (if (setq FH (open FName "r"))
          (while (setq LINE (read-line FH))
            (if LINE
              (if (setq Comma (vl-string-position (ascii ",") LINE ))
                (if (setq LblStr (substr LINE 1 Comma))
                  (if (setq RemStr (substr LINE (+ Comma 2))
                             Comma (vl-string-position (ascii ",") RemStr)
                    (if (setq Xord (substr RemStr 1 Comma)
                            RemStr (substr RemStr (+ Comma 2))
                              Yord (substr RemStr 1 Comma)
                          (setq DatITM (list LblStr (atof Xord) (atof Yord))
                                DatLST (append DatLST (list DatITM))
                        (princ (strcat "\n   Bad line '" LINE "'"))
              (close FH)
          (princ "\n  Unable to Open File!")
        (princ "\n  No File Picked!")
      (if DatLST
        (setq DatLST DatLST)
        (eval nil)
    ;;;____________________________________________________________________________
    ;;;  Program to Insert Points and Text at each location in list
    (defun C:PlacePTS ( / PosLST ITM Lbls Xord Yord TxtPT)
      (setq PosLST (ReadUTM))
      (if PosLST
          (setvar "CMDECHO" 0)
          (command "UNDO" "Begin")
          (foreach ITM PosLST
            (setq Lbls (car   ITM)
                  Xord (cadr  ITM)
                  Yord (caddr ITM)
            (princ (strcat "\n Placing " Lbls))
            (command)
            (if (> (atoi Lbls) 5)
              (setq TxtPT (polar (list Xord Yord 0.0) 0.0 -700.0))
              (setq TxtPT (polar (list Xord Yord 0.0) 0.0 0.0))
    (command "_Text" "_non" TxtPT "150" "0" Lbls)
            (command)
          (command "UNDO" "End")
          (setvar "CMDECHO" 1)
          (princ (strcat "\n  Placed " (itoa (length PosLST)) " items."))
        (princ "\n  Nothing to place.")
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,738
    A quick modification of my code from here, should perform as required:
    Code:
    (defun c:txtatpt ( / f p s x y )
        (if
            (and
                (setq f (getfiled "" "" "csv" 16))
                (setq f (open f "r"))
                (while (setq n (read-line f))
                    (if
                        (and
                            (setq p (vl-string-search "," n))
                            (setq s (substr n 1 p))
                            (setq p (vl-string-search "," (setq n (substr n (+ p 2)))))
                            (setq x (distof (substr n 1 p)))
                            (setq y (distof (substr n (+ p 2))))
                        (entmake
                            (list
                               '(0 . "TEXT")
                                (list 10 x y 0.0)
                                (cons 1 s)
                                (cons 40 (getvar 'textsize))
                (close f)
    Lee Mac Programming
    Just another Swamper
  1. Placing text in circle
    By richard3009 in forum AutoCAD General
    Last Post: 15th Jul 2011, 04:19 pm
  2. Placing text on a solid
    By pauledward in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Nov 2009, 02:43 pm
  3. Placing text
    By YoyoGraphics in forum AutoCAD General
    Last Post: 14th Jul 2009, 03:48 am
  4. Placing text acurately
    By richard3009 in forum AutoCAD Beginners' Area
    Last Post: 21st May 2009, 05:54 pm
  5. question about placing numbered text
    By ledesmaf71 in forum AutoCAD General
    Last Post: 29th Jan 2007, 12:18 am
